Author Topic: Orientation problem with Mame  (Read 1342 times)
« on: January 20, 2006, 10:25:23 pm »
I'm so happy I got Mamewah working - but I'm having an issue with games like Pacman, MsPacman, Frogger, etc. that use an orientation different then a standard monitor. It automatically flips the image 90 degrees to the left. If I go to a dos prompt and run the game from Mame it does it also.
I created a mame.ini config and I see all kinds of options in here. Can someone tell me which one will stop the rotation?
Re: Orientation problem with Mame
« Reply #1 on: January 21, 2006, 01:24:00 pm »
I've played with some settings and didn't have any luck. Here is what my mame.ini looks like. I'm sure it's something obvious. Any help will be greatly appreciated.
### mame.ini ###
### Frontend Related ###
### Windows path and directory options ###
rompath                 roms
samplepath              samples
# inipath               <NULL> (not set)
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snap
diff_directory          diff
ctrlr_directory         ctrlr
cheat_file              cheat.dat
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
direct3d                0
hwstretch               1
# screen                <NULL> (not set)
cleanstretch            auto
resolution              auto
refresh                 0
scanlines               0
switchres               1
switchbpp               1
maximize                1
keepaspect              1
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_brightness   0.000000
frames_to_run           0
effect                  none
screen_aspect           4:3
### Windows Direct3D 2D video options ###
zoom                    2
d3dtexmanage            1
d3dfilter               1
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               none
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
### Windows misc options ###
sleep                   1
rdtsc                   0
high_priority           0
### Windows sound options ###
audio_latency           1
# wavwrite              <NULL> (not set)
### Input device options ###
mouse                   0
joystick                0
lightgun                0
dual_lightgun           0
offscreen_reload        0
steadykey               0
keyboard_leds           1
led_mode                ps/2
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
paddle_device           keyboard
adstick_device          keyboard
pedal_device            keyboard
dial_device             keyboard
trackball_device        keyboard
lightgun_device         keyboard
digital                 none
### Mame CORE video options ###
norotate                0
ror                     0
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
gamma                   1.000000
brightness              1.000000
pause_brightness        0.650000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                 0.000000
intensity               1.500000
### Mame CORE sound options ###
samplerate              44100
samples                 1
sound                   1
volume                  0
### Mame CORE misc options ###
artwork                 1
use_backdrops           1
use_overlays            1
use_bezels              1
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# debugscript           <NULL> (not set)
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
oslog                   0
skip_gameinfo           0
bios                    default
# state                 <NULL> (not set)
autosave                0
### Configuration options ###
readconfig              0
verbose                 0
« Reply #2 on: January 21, 2006, 04:29:15 pm »
also -
It's version 1.03
There is a switch in the mame.ini that says norotate and has a 0. I changed it to 1 (and I was thinking... this HAS to be it) and it didn't help.
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #3 on: January 21, 2006, 09:18:37 pm »
Your video chip isn't an onboard intel chip is it?
« Reply #4 on: January 22, 2006, 03:07:00 am »
It is the onboard intel video chip....
Let me look at it's settings. I didn't think to look there - whats your thoughts? I'll report back if I see anything that will help.
« Reply #5 on: January 22, 2006, 03:17:18 am »
I didn't see anything in the control panel...
I put a video card in and disabled the onboard card and it works. Thanks for the tip.
Any idea why the onboard intel does that?
Popcorrin
« Reply #6 on: January 22, 2006, 12:53:13 pm »
I'm not sure why it does it but I had the same thing happen with an intel chip.  I think the consensus is that onboard intel isn't much of a chip for gaming.
« Reply #7 on: January 22, 2006, 03:28:21 pm »
Ok. Good to know.
Thanks for the heads up - I was scratchin my head with this one.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: January 23, 2006, 02:16:33 pm »
Intel onboard video has a feature that "automatically rotates" screens that are taller than they are wide.
I heard the setting can be changed, but it's hidden somewhere deep in the tapped (I don't have one ATM).
Robin
Knowledge is Power
