Author Topic: wiring a Wico?  (Read 807 times)
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
wiring a Wico?
« on: January 19, 2006, 07:54:40 pm »
I just received the 4-way Wico NOS from Nicade and was wondering which terminal to use for ground and which for regular direction...I can't see any labels for common or positive
I have only ever used T-sticks and Happs which were microswitches
This joy does seem like it will be sweet for 4-way though.. ;D
thanks
BobA
  • What Me Worry?
Re: wiring a Wico?
« Reply #1 on: January 19, 2006, 08:13:01 pm »
A leaf switch should have only 2 terminals.  It does not matter what is hot or gnd as there are only 2 terminals to connect to.
« Last Edit: January 19, 2006, 08:23:08 pm by BobA »
deadmoney5
Re: wiring a Wico?
« Reply #2 on: January 19, 2006, 08:59:53 pm »
so if you use the higher terminal for one, should I use the higher terminals for all 4 wires?
or doesn't it matter at all?
markrvp
  • NFL Expert
Re: wiring a Wico?
« Reply #3 on: January 19, 2006, 09:05:57 pm »
It doesn't matter, but it looks nicer if you use the same terminal on each switch.
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
Re: wiring a Wico?
« Reply #4 on: January 19, 2006, 10:15:47 pm »
Which is only important to those arrogant SOBs who lift up their CPs to show-off their wiring :P
:D  I kid!
« Last Edit: January 20, 2006, 01:23:11 am by quarterback »
-- Chad Tower
deadmoney5
Re: wiring a Wico?
« Reply #5 on: January 19, 2006, 10:50:56 pm »
thanks for the help
