Author Topic: removing Windows XP and Manufacture logos from startup?  (Read 1643 times)
Otraotaku
  • Last login:September 21, 2017, 09:55:25 am
  • トラビス
« on: January 19, 2006, 05:19:33 pm »
hey guys, im currently setting up a 2nd computer to use for mame and think it would be a bit more athentic to replace all the start up screens with either blank or start up data screens... (cab logos) etc
its windows XP home, and the machine is an emachines... i have seen some programs that do some stuff like that, but id rather know what not to do .... what do you reccomend doing
LJHalfbreed
  • Last login:April 13, 2006, 09:10:21 am
  • I'm a mammal!
Re: removing Windows XP and Manufacture logos from startup?
« Reply #1 on: January 19, 2006, 06:39:20 pm »
http://articles.networktechs.com/17-p1.php
User XP
Alternatively, the ceator of GameEx made a great 'frontend sheller'.
http://tomspeirs.com/gameex/Shell.htm
It's called instant sheller, and might be better for you if  you're afraid of the first route. If ya like it, toss him some donation cash... I think he needs it. :)
HTH!
hnugz
  • Last login:September 14, 2013, 06:18:38 pm
    • Horrorcore Games
« Reply #2 on: January 19, 2006, 08:05:02 pm »
I use http://www.stardock.com/products/bootskin/ with this
for boot screen anyway.
« Last Edit: January 22, 2006, 07:05:49 am by Peale »
"Don't play pinball if you only got one arm, cuz your score will suck."
Otraotaku
  • トラビス
« Reply #3 on: January 19, 2006, 10:46:59 pm »
my computer is now in safe mode... >.< it screwed up mine...
« Last Edit: January 22, 2006, 07:06:19 am by Peale »
Otraotaku
  • トラビス
« Reply #4 on: January 22, 2006, 01:15:01 am »
i found a boot skin of Strider XP, and i absolutely gotta have this one running on my computers boot screen for Windows, but i cant seem to get it workin?
everytime i try it doesnt locate the actual screen and the only way back in is through safe mode, any suggestions?
LJHalfbreed
  • I'm a mammal!
« Reply #5 on: January 22, 2006, 01:42:04 am »
Not sure what the problem could be, unless
A.) You have the file saved in the wrong place
or
B.) the file isn't saved as the correct size/depth/filetype
or
c.) You missed one of the instructions
or
d.) a mixture of the above.
So... what software/technique did you use to put in the boot screen, for starters?
Otraotaku
  • トラビス
« Reply #6 on: January 22, 2006, 09:53:03 am »
or
or
or
bootskinXP
WTB
  • Last login:May 09, 2019, 10:15:35 pm
    • ihateyourband.net
« Reply #7 on: January 22, 2006, 11:20:42 am »
littlewhitedog.com (Here) has an article about how to do this manually. Well, for the boot logo at least. It was written for Win2k but works the same in XP. Been using this method for years. Its hard to mess up and always leaves you a way out.
   -Matt
Otraotaku
  • トラビス
« Reply #8 on: January 22, 2006, 11:55:10 pm »
   -Matt
thanks ill try it first thing when i find the time... ^.<
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #9 on: January 23, 2006, 02:38:35 pm »
You can also do a little bit of "cheating" by turning off the logon screen @ startup, hiding the desktop icons, make your background solid black, and placing your FE in the startup menu so it comes up immediatly. I even added a personalized .wav file to let me know Windows booted properly. You wouldn't even know its running a Microsoft OS until you hit the power button (to tur it off) which ends the PC into hibernation and displays the "Windows is hibernating" logo.
Signature tags are dumb.
gonzo90017
« Reply #10 on: January 23, 2006, 11:52:56 pm »
Right click 'My Computer' then click Properties. Under the 'Advanced' tab, click Settings next to Startup and Recovery. Click Edit.
After the command /fastdetect add /bootlog /noguiboot. So the end of the line should look like this /fastdetect /bootlog /noguiboot notice the spaces!!!
Now drop a 16 colour, 640x480 bmp file named boot.bmp into C:\Windows
That's it!
