Main > Main Forum
DOS Mame Cabinet - which i-pac to purchase
Pages: << < (2/2)
bradleyj00:
Thanks for the replies.
Here's a little more info about defcade:
http://def.buste.de/
bradleyj00:
Sounds like the KeyWiz Eco 2 will do the job. What about the trackball and/or spinner? Can I simply duplicate the wiring currently used on my joystick? I assume the trackball and spinner simply tie into the up/down/left/right buttons....or will I require and additional interface for this?
Thanks again,
Jim
Tiger-Heli:
--- Quote from: bradleyj00 on January 17, 2006, 05:09:09 pm ---Sounds like the KeyWiz Eco 2 will do the job. What about the trackball and/or spinner? Can I simply duplicate the wiring currently used on my joystick? I assume the trackball and spinner simply tie into the up/down/left/right buttons....or will I require and additional interface for this?
Thanks again,
Jim
No - you need a different interface.  RandyT just released the Opti-Wiz which should do the job - See this thread (http://forum.arcadecontrols.com/index.php?topic=47866.0)
Actually, on further review, it's not released yet, but if you're ordering an Eco, you might talk him out of one.  Or you could hack a mouse - lots of links here - http://www.mameworld.net/tigerheli/encoder/main.htm#49
Lastly, you could buy an Opti-Pac from www.ultimarc.com, but it's probably overkill for a simple trackball/spinner connection.
Grasshopper:
--- Quote from: Tiger-Heli on January 17, 2006, 08:07:23 am ---The VE is out, as is the Mini-PAC, as the trackball/spinner interface only works in USB mode.
The KeyWiz from www.groovygamegear.com would also be an option, but it lacks EEPROM, so you have to either use the default codeset (which is very good for MAME), or program it before each use.  The DOS version of the KeyWiz software lacks the fancy GUI, but it does work.
I wouldn't rule out the Mini-PAC. It's true that you won't be able to use the trackball/spinner side of  the interface in ps/2 mode but it's still cheaper than a regular Ipac.
Tiger-Heli:
--- Quote from: Grasshopper on January 18, 2006, 09:25:27 am ---I wouldn't rule out the Mini-PAC. It's true that you won't be able to use the trackball/spinner side of  the interface in ps/2 mode but it's still cheaper than a regular Ipac.
Valid point, although it's still more than the KeyWiz Eco.
Pages: << < (2/2)
Go to full version
