Main > Main Forum
One handed games
JoyMonkey:
Here's some MAWS search results:
Games that use 0 buttons and a 4-way joystick
Games that use 0 buttons and an 8-way joystick
Games that use 0 buttons and a trackball
Probably not 100% accurate.
markrvp:
You can play Golden Tee with one hand. Use the good hand to select "turn right" or "turn left" and then use the same hand to roll the trackball.
Same thing with Shuuz. Somebody already mentioned ShuffleShot, and don't forget World Class Bowling.
All of these are great trackball games (and you have a pretty red trackball).
telengard:
Trogdor!
Oh, wait you meant arcade games ;)
Frogger comes to mind.
~telengard
More Cowbell:
If you find yourself bored with the no-button games, just use your face to smash the buttons when needed. I'd like to see you play defender. I just wrote this so that I could picture it in my head. It's even better than I thought.
Thenasty:
if the player has only one hand, he can use his foot once you install the button(s) below.
You can call his CAb "StompCade" or "1-HandCade"
You can still use 1 button or 2 if you like, just use the josticks w/Trigger buttons.
