Author Topic: Need dos MAME 0.78 with keyboard LEDs enabled for all games  (Read 1519 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: January 10, 2006, 05:23:22 pm »
So, where do I go to get a build of DOS MAME 0.78 with keyboard LEDs enabled for ALL games?
« Last Edit: January 11, 2006, 06:09:07 pm by RayB »
NO MORE!!
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
Re: I need DMAME 0.78 with LED support
« Reply #1 on: January 10, 2006, 05:47:43 pm »
What do you mean by led support?
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:March 25, 2023, 09:38:52 am
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #2 on: January 10, 2006, 06:33:15 pm »
You could use AdvMame 0.78 and add a few scripts to the config to work the keyboard LEDs.
Here's the scripting doc:
http://advancemame.sourceforge.net/doc-script.html
Light the third keyboard led when the 'coin1' key is pressed :
script_coin1 on(0, 0b100); delay(500); off(0, 0b100);
RayB
  • There's my post
    • RayB.com
« Reply #3 on: January 10, 2006, 07:39:51 pm »
You know how in Atari games, you insert a coin and then the first keyboard LED flashes on and off? And then if you insert a 2nd coin, both the first and second keyboard LEDs flash? That's what I want, but for all games, not just Atari and Pacman.
It's supported in some older versions of MAME but then at one point they decided to disable it for game that never had lit start buttons in real life. I'm sure adding it back in is just a matter of tweaking a couple lines of code.
« Last Edit: January 11, 2006, 12:04:43 am by RayB »
NO MORE!!
Spartan
  • Last login:December 02, 2009, 07:09:38 pm
  • I like stuff!
    • The Municade
« Reply #4 on: January 13, 2006, 09:24:57 am »
Did you ever figure this out?  I'd like to put it into my build as well.
SirPoonga
  • Puck'em Up
Re: Need dos MAME 0.78 with keyboard LEDs enabled for all games
« Reply #5 on: January 13, 2006, 10:26:31 am »
sounds like something that should be added to coindrop.
2600
« Reply #6 on: January 13, 2006, 10:55:01 am »
Coindrop is windows.  RayB is talking about DOS.  I don't think the old version of MAME did it with all games, just the ones that had "support" for it.  They then cleaned it up for the games that actually used it, ie actually had lightable buttons.
If you wanted it for ALL games, it would require more work.
