Main > Main Forum
BEST 4-way joystick??
Pages: << < (5/5)
deadmoney5:
it is indeed for a p360...
fiddling? ???
RayB:
--- Quote from: deadmoney5 on January 10, 2006, 09:05:03 pm ---I just bought that one in the auction...I guess I will need a longer shaft since I have a wood panel....
Don't worry about it. It's not that short. I use 3.5" wicos on a wood cp too. I like em low like that.
quarterback:
--- Quote from: RayB on January 10, 2006, 11:44:55 pm ---
Me too.
My cab had four 3.5" Wicos in a 3/4" thick CP with a bit routed out underneath (I'd guess 1/4").  I currently have two of them in my temporary 1/2" thick CP (with no routing out) and I think they're perfect.   So I wouldn't sweat it deadmoney5.
Try it out and if you decide that it's too low, buy a 4" replacement shaft from ponyboy.
Kremmit:
--- Quote from: deadmoney5 on January 10, 2006, 11:26:27 pm ---it is indeed for a p360...
fiddling? ???
Try it out when you get it- you'll see.  You may need to add a washer between the e-clip and the actuator.
nostrebor:
Mine are all WICO leaf sticks. I recessed the unit into the top of the control panel. It works just dandy. I have played them either way and it really isn't that big of a deal for play, top-mounted vs. bottom-mounted. The NOS ones are a bit stiff at first, but I suspect that you will love the feel of this 4-way.
Pages: << < (5/5)
Go to full version
