Author Topic: Wow, Happ Ultimates really do stink...  (Read 1416 times)
Yoder
  • Last login:November 22, 2006, 04:35:24 pm
« on: January 07, 2006, 03:45:19 pm »
I bought a Happ Ultimate not realizing that it was a Happ Ultimate (thought it was just a generic ebay joystick for a cheap project I'm working on).  I installed it in my X-arcade box (perfect fit w/o mod.) to try it out, and it is absolutely garbage!  Most games (4 AND 8 way) are basically unplayable because you're always hitting diagonals and your player just stops or goes the wrong direction!  I can't believe these were ever installed in REAL arcade machines!
I'm assuming Happ Supers, Competitions, and Ultimate POS's all have the same footprint/bolt spacing...correct?  Does anyone know what other joysticks are compatible?  I'd like to try a few out in my X-arcade w/o having to cut it...esp the 49-way, but I doubt it's compatible with the X-arcade's encoder.
markrvp
  • NFL Expert
Re: Wow, Happ Ultimates really do stink...
« Reply #1 on: January 07, 2006, 03:58:23 pm »
Happ 49-way, P-360, Wicos all have the same footprint.  The 49-way is not compatible with the X-arcade encoder.
Yoder
« Reply #2 on: January 07, 2006, 04:29:46 pm »
Thanks!  And do these 3 share the same footprint as the other Happs (Ultimate, Super, Comp)?  Sounds like I've got a lot of choices...except for the Ultimarcs.
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #3 on: January 07, 2006, 06:59:41 pm »
I like my Happ Comps. I did mount them using holes drilled for my original T-Stick +'s (didn't like stiff feel). If I remember correctly, the T-Stick bases were wider, but the holes lined up.
Going from T-Stick to Happ might be easier than the other way around.
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
« Reply #4 on: January 07, 2006, 07:18:44 pm »
Was the hole for the shaft the same on the T-Sticks and the Happs? Didn't mean to rob your thread, just curious.
I had to beat them to death with their own shoes...
hnugz
  • Last login:September 14, 2013, 06:18:38 pm
    • Horrorcore Games
« Reply #5 on: January 07, 2006, 07:58:28 pm »
I bought a couple of these myself before I really knew what I was getting, and although I haven't hooked em up, I already bought a couple supers based upon what everyone says.  Thanks for the additional info on how crappy they are.
"Don't play pinball if you only got one arm, cuz your score will suck."
TOK
« Reply #6 on: January 07, 2006, 08:21:38 pm »
Not sure. I swapped complete sticks... I think what you're asking me is if the Happ will mount on the Ultimarc plate???
If you just mean did I have to enlarge holes for the Comps due to the Ultimarc's shaft size or throw, no I did not. I used a standard Street Fighter template/hole size for sticks.
SNAAKE
  • Trade Count: (+29)
  • Last login:January 11, 2024, 12:21:50 pm
  • my joystick is bigger than your joystick !
« Reply #7 on: January 08, 2006, 05:56:37 am »
ultimates arent too bad I can do just about anything in any game but other sticks are just better(super,comp,etc)
