Main > Main Forum
how do i set up MARS coin mech on mame cab
Pages: << < (2/2)
grayxx:
--- Quote from: Jess-- on January 08, 2006, 08:47:46 am ---I have a mars coin mech on my cab... I will look at how I have it hooked up in a bit and post back (works perfectly btw)
thanx Jess-- looking farward to it
Jess--:
ok mine is is an MS111 which looks older than the one you have it is wired as follows.
according to the markings on the board (screw terminals on mine)
+12 (hooked up to original cabinets psu)
Gnd connected to original Cab gnd and to Jpac Gnd
Cred goes into Jamma harness but if used on an Ipac would connect to Coin1 input
Lamp Not connected
Mtr connects to my mechanical meter (not required)
My mars system has a cable between the actual coin slot and the board, you may need to make yourself one up as it does not look as if yours is connected in your picture.
Ken Layton:
Contact tech support at the manufacturer, www.meiglobal.com
grayxx:
cheers Jess-- good help, but i think that top strip that you have your wires coming out is worded different to mine, i have under my strip SUPPLY with a black and yellow wire, GAME with a green wire, METER with no wires and LAMP with black and yellow/red wire, so how does yours read?????
Jess--:
supply on yours should be the same as +12v and Gnd on mine
Game = Credit
Meter = mechanical meter (12v pulse output)
Lamp = Lamp outputs (for lighting coinslots)
Pages: << < (2/2)
Go to full version
