Main > Main Forum
Im looking for some feedback on my CP layout
Pages: << < (3/3)
RayB:
--- Quote from: tahnok100 on January 08, 2006, 01:59:21 am ---Those buttons seem awful close HarumaN. Do you have any problems with them?
Those are not close.
walls83:
--- Quote from: RayB on January 09, 2006, 01:58:09 pm ---
If anything they might be too far apart.. Atleast for my taste
Lilwolf:
One of the best things I can say is..
buy some cheap wood (particle board is about 4 bucks a 4x8 sheet.  And create  a mock up.  If you can, get it all wired and use it for a week or so and try.  And heck, try it a few times and see what you like.
I've redone my 2 player fighter control panel like 5 times.  Each time I did it really nice and wish I had just tried it.  After you get it right, then finish it with nice wood, perfectly spaced,
I would recommend doing them in lines myself without the curves.  It seems like it would be comfortable, but if you aren't used to them that way, it will be annoying.  I don't lay my hand down when I play... so its not ergonomic anyway.
But if you make a test control panel... try player 1 one way, and player 2 another and see what you like.
Hoopz:
--- Quote from: Lilwolf on January 09, 2006, 02:12:11 pm ---One of the best things I can say is..
Ditto.
HaRuMaN:
This layout fits my fingers perfectly.  I played around making cardboard mockups before I settled on a final spacing, as you see in the picture.
Pages: << < (3/3)
Go to full version
