Author Topic: I just killed my DeWalt drill. Anyplace to get refurb motors?  (Read 2004 times)
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« on: January 05, 2006, 03:00:14 am »
I somehow burnt out my 14.4v DeWalt drill tonight.  I'm very unhappy since it's not an inexepensive item and I've only had it a little over 2 years.   :(
Since I've got some torx bits, I took it apart to see if something had just broken loose or something, but it's pretty clear that everything's working except for the motor itself.
It's out of warranty and I don't particularly want to deal with taking it into an "official DeWalt Service Center" if I can just replace the motor myself.  Anybody know of a place to pick up a replacement?
-- Chad Tower
Witchboard
Re: I just killed my DeWalt drill. Anyplace to get refurb motors?
« Reply #1 on: January 05, 2006, 08:34:42 am »
You should be able to have the "official DeWalt Service Center" order you a replacement motor.  One of the battery connectors in my handle bent over and I managed to fry the motor in mine also.  I went to a DeWalt store we had here and just ordered a replacement motor since installation would have cost more.  It's pretty easy to swap out.
MikeQ
« Reply #2 on: January 05, 2006, 08:45:04 am »
I dropped my 18v from a ladder and snapped the casing off at the hand grip.  I found a new casing and many other parts at:    I ordered a new case and the drill is as good as new.
http://www.toolpartsdirect.com/dewalt/dewalt-7.html
Dervacumen
  • Last login:February 13, 2019, 10:11:11 pm
  • Home of Three Squares dice game
    • Beaker Games
« Reply #3 on: January 05, 2006, 11:34:14 am »
DeWalt also has a ceiling price on repairs for any of their tools.  You should call up the service center near you (or any one, really) and give them the model number and type (it's on the label) of your drill.  With that info they can look up the motor part number and give you a price.  More than likely they'll have the motor in stock.  Then ask how much a "max repair" is and see if it makes sense to have them do it for you.  "Max repair" means just that - they'll replace anything and everything that is bad.  You might want to get a new set of brushes, too.  They are pretty cheap and since they are a wear part you might as well replace them at the same time.
If you go the max repair route, you might want to "accidentally" crack the case near the trigger before you take it in.  Ask them to replace the clamshell housing and the motor.  Makes it look just like new!
Usually the motor is about $60-$70 and a max repair is about $30 more.  Total cost on the max repair will be about 50% of what the tool retails for.
Don't tell them I told you that.
Bringing to life a child's imagination.
quarterback
« Reply #4 on: January 05, 2006, 02:44:59 pm »
Thanks for all the replies.
I'll do some repair/max repair  investigation and if not that, order from the page that MikeQ linked.
-- Chad Tower
southpaw13
  • Last login:October 31, 2020, 05:11:18 pm
  • Whatever!
« Reply #5 on: January 05, 2006, 06:21:51 pm »
Check e-bay.  Contractors buy the sets and only use the batteries.  You can find a drill and case (no battery) cheap sometimes...
Zakk
  • Last login:May 06, 2024, 10:05:51 pm
« Reply #6 on: January 05, 2006, 06:49:25 pm »
There's supposed to be a way to replace the inside part of the batteries too, I've been looking for that, since I have 7(!!) 18V batteries that have started to show their age...    :'(
extremepong
  • Last login:February 26, 2007, 08:17:32 am
« Reply #7 on: January 05, 2007, 08:37:00 pm »
Can you keep taking apart the motor. Maybe it's just the brushes or a bearing.
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
« Reply #8 on: January 05, 2007, 09:03:45 pm »
That's what I was gonna say...LOL!
Xam
Can't talk to a psycho like a normal human being.
PoDunkMoFo
  • Last login:January 25, 2024, 07:27:17 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
« Reply #9 on: January 05, 2007, 10:02:33 pm »
If you take the battery apart it's just rows of rechargeable cells.  Match the cells solder them together and there ya go.  No sure if it's economical never tried it but I have seen the inside of the bat.
Zakk
« Reply #10 on: January 05, 2007, 10:08:15 pm »
I ended up getting some chineese replacement batteries, cheap and they work well.  I don't know if they will last as long as the originals, but they were about 1/3 the price.  So I got Ni-MH cells for less than the price of Ni cad batteries.  They came in about 3 days, and work great
http://www.battery-pro.net/power-tools-battery/model.php/DEWALT/8307/DW999#
