Author Topic: Can I install two Mame applications on the same computer?  (Read 767 times)
unclet
« on: January 03, 2006, 08:31:01 pm »
I have v81 already installed on my computer and would like to install v103 as well, while keeping v81 installed.
If I install the Mame-v103 in a separate directory then will there be any problems executing either v81 or v103 (whichever I want)?
I want to make sure there are no registry, highscores, etc ... stuff which will cause problems if I have two different versions of Mame installed at one time....
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
Re: Can I install two Mame applications on the same computer?
« Reply #1 on: January 03, 2006, 08:51:05 pm »
yes
SirPeale
  • Green Mountain Man
« Reply #2 on: January 03, 2006, 09:35:50 pm »
Don't do it!  Otherwise your eyes will explode, and some ooze, perhaps eye-goop, will drip from the sockets.  And you'll die.
MYX
    • MYX Digital Blog
« Reply #3 on: January 03, 2006, 10:42:42 pm »
yeah, don't cross the streams either.
M    Y    X
unclet
« Reply #4 on: January 03, 2006, 11:01:57 pm »
Dont cross the streams ..... funny!
JODY
  • Last login:January 19, 2024, 05:06:29 pm
  • After a long delay...the arcade is underway!
« Reply #5 on: January 08, 2006, 02:40:24 pm »
Versions of Mame32 used registry settings for some things a year or two ago.
« Last Edit: January 08, 2006, 02:43:31 pm by JODY »
metaHipster
  • Last login:January 10, 2010, 06:09:19 pm
  • Taking the next level to the next level
    • MetaHipster's Arcade Blog
« Reply #6 on: January 09, 2006, 01:41:47 pm »
Mamewah (and probably other FE's) will let you configure one emu/menu for one version and another for the other -- you can then switch to the appropriate emu to see whichever games you've got intended for it (as defined by maintaining separate ROM folders)...
Lilwolf
« Reply #7 on: January 09, 2006, 03:47:14 pm »
I've been using multiple versions of mame for years with my frontend.
It started with the sega rewrite not being done for a few years... and I wanted to be able to play shinobi and others.
so I had two versions.
Now I use it for analog+mame for the games that require it... and mameplus for all the others (I love being able to read the game docs on my cab without extra keys)
