Author Topic: Monitor Favor for a Happs Vision Pro 19 in.  (Read 1009 times)
MYX
    • MYX Digital Blog
« on: January 02, 2006, 07:00:05 pm »
If any of you have a Happs Vision Pro 19 in (preferably universal mount) can you take some pictures and post em here. They do not give much of an idea about hook up on the Happ site.
I am looking for 3 images a full frontal shot so I can see the mounting brace, a general  rear end shot, and then a close up of of the RGB-Ground-Sync section. I know that my pict descriptions are going to get me into trouble, but hopefully the EE crowd will go light.
I am gearing up to build this thing and have about $500 in stuff collected. I just have some questions about hook up.
M    Y    X
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Monitor Favor for a Happs Vision Pro 19 in.
« Reply #1 on: January 02, 2006, 07:03:47 pm »
I've got one on the way, but it may be a while ...
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
koolmoecraig
    • My Intervention
« Reply #2 on: January 02, 2006, 11:00:28 pm »
Here is the back of the monitor with the RGB-Ground-Sync section circled.
The mounting is the same as any other monitor I have seen. I've used one on my Q*bert and Rally-X machines and they both just drop right in the original mounting holes.
Let me know if I can answer anything for you.
« Last Edit: January 02, 2006, 11:02:35 pm by koolmoecraig »
MYX
    • MYX Digital Blog
« Reply #3 on: January 03, 2006, 12:06:37 pm »
Do you know what the connector type is that connects to the monitor? I previously used butt connectors and had to slide each one on to each pin. I would rather do it properly.
M    Y    X
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: January 03, 2006, 12:43:02 pm »
I don't know why people assume that they need to buy connectors seperately. But here you go: That monitor comes with a connector and wiring.  If yours didn't come with it, then call Happ and complain.
« Last Edit: January 03, 2006, 12:56:54 pm by RayB »
NO MORE!!
koolmoecraig
    • My Intervention
« Reply #5 on: January 03, 2006, 06:19:45 pm »
Yeah it comes with a pre-wired connector. And even if it didn't, you just go buy a molex connector and bingo.
dagintm
  • Last login:October 14, 2007, 10:04:51 am
    • home page
« Reply #6 on: January 03, 2006, 08:58:45 pm »
Here are some pictures of mine mounted in a cocktail cab. good side view.
had to cut the connector and flip each side to get the monitor to display on the correct side during boot.
