Author Topic: how to get rid of the disclaimer in mame 102  (Read 3683 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: December 31, 2005, 05:15:05 pm »
how do i do that. i looked in the mame config file and it only had the option of not displaying the game info? i thought they got rid of the press ok to continue but i maybe was wrong?
Buddabing
Re: how to get rid of the disclaimer in mame 102
« Reply #1 on: December 31, 2005, 05:16:48 pm »
They have a couple of warnings you can't disable without changing the code.
Please read the wiki!
GMZombie
« Reply #2 on: December 31, 2005, 05:25:26 pm »
oh ok...does anybody know how to do that? eh its not that big of a deal i just wanted to upgrade my other machine and that didnt have them in it? didnt they used to have skip disclaimer in there..
SirPeale
  • Green Mountain Man
« Reply #3 on: December 31, 2005, 05:52:36 pm »
It only displays once.  Then never again.
Except for game warnings; those still display no matter what.
MikeQ
« Reply #4 on: January 01, 2006, 12:10:57 pm »
In these functions just do a  "return 0" after the local variable declarations.
int ui_display_copyright(mame_bitmap *bitmap)
int ui_display_game_warnings(mame_bitmap *bitmap)
int ui_display_game_info(mame_bitmap *bitmap)
headkaze
  • 0x2b|~0x2b?
« Reply #5 on: January 03, 2006, 07:44:59 am »
Or change to these lines in mame.c
Code: [Select]
/* if we didn't find a settings file, show the disclaimer */
if (settingsloaded || options.skip_disclaimer || 1)
/* show info about incorrect behaviour (wrong colors etc.) */
if (options.skip_warnings || 1)
/* show info about the game */
if (options.skip_gameinfo || 1)
electricd
  • Last login:August 05, 2011, 03:30:33 pm
  • I'm not a llama!
« Reply #6 on: January 13, 2006, 10:53:37 am »
Just found this thread and used headkaze's method for disabling.  After I compile, do I have to turn on any switches to make this happen, or did the lines I changed automatically take care of business for me?  Thanks!
Farmboy90
  • Last login:June 26, 2006, 12:15:04 am
  • My cab is done... Pics coming soon!!
« Reply #7 on: January 13, 2006, 10:55:39 am »
If you used his method then no, nothing else is needed.  Just compile and things will be fine for you.
electricd
  • I'm not a llama!
« Reply #8 on: January 13, 2006, 02:08:34 pm »
OK just re-compiled MAME with the changes, but still seeing the "OK" screen.  If I set the "skip_gameinfo" to 0 I still see the game info as well.  I changed these lines in Mame.c
Original:
   if (settingsloaded || options.skip_disclaimer || ui_display_copyright(artwork_get_ui_bitmap()) == 0)
      if (options.skip_warnings || ui_display_game_warnings(artwork_get_ui_bitmap()) == 0)
         if (options.skip_gameinfo || ui_display_game_info(artwork_get_ui_bitmap()) == 0)
Changed:
Not sure what gives?  Can anyone help?
Farmboy90
« Reply #9 on: January 13, 2006, 03:36:40 pm »
Original:
Changed:
Hummm, you sure you are using the newly compiled version?   :)
I would just open usrintrf.c and and modify the methods themselves.
Use MikeQ's method, that will do the trick:
BuZz880
  • Last login:November 16, 2023, 02:16:43 pm
« Reply #10 on: January 13, 2006, 06:28:48 pm »
Hmmm... not to interrupt your technical discussion because I am glad this is being documented somewhere but for many like myself that find compiling each version of mame cumbersome, here's an alternative.
I just ran a game at random then took the cfg that was generated and copied it to ..\cfg\<romname>.cfg for every rom I had using a bat file.
If you have any custom settings in a couple of your cfgs then make sure you do not over-write those particular games.
eightbit
  • My cab is never done...
« Reply #11 on: January 19, 2006, 09:15:34 pm »
What was your batch file? What did you use to generate the list of roms?
