Author Topic: WTBorrow 3.25" Hole Saw  (Read 1790 times)
LPZ
  • Last login:April 11, 2015, 01:55:21 pm
  • 2nd place is the first loser!
« on: December 29, 2005, 09:02:11 am »
Just wanted to know if there is anybody out there that is willing to let me borrow their 3.25" hole saw to make a hole in my CP for my happs trackball.  I hate to buy one for $25 and probably use it only once. I know a man's tools are kinda personal to them, but I thought I'd give it a shot.   Anyway, I will pay shipping both ways, and throw in a couple of items for free for the usage(i.e. buttons, connectors, etc.)
thanks,
LPZ
Dual 50 Caliber Continuous Fire Leon Type Machine Guns......OH YEAH!!!!!
WwonderLlama
  • Last login:July 01, 2009, 03:56:56 pm
  • I _am_ a llama!
    • MAME gallery (working link!)
Re: WTBorrow 3.25" Hole Saw
« Reply #1 on: December 29, 2005, 10:26:48 am »
Just as a thought, I bought a hole cutter that's designed (I think) for a drill-press.  It's basically a drill bit with an arm that connects to an adjustable metal cutter (so you can change the radius of the hole.  IIRC, the bit cost me about $8.
Get ready for some ascii art:
         (bit)
           ||   (arm)
           ||__________||__
                       (cutter)
Anyway, I bought this instead of a holesaw.  I didn't see the sense in paying $25 for something I'd use once either.  Instead, I paid about $8 for something I used once. ;)
Anyway, if you'd like to try it, I'm sure it'd cost less than shipping someone else's holesaw back and forth.
As a side note, I believe I used my drill in reverse when using this, but in retrospect, it's probably not necessary.  Just use your drill at a semi-slow speed and all should be well.
Edit: made ascii art a little clearer... (maybe?)
« Last Edit: December 29, 2005, 11:20:32 am by WwonderLlama »
At it once again.
Doc Thirst
  • Last login:November 18, 2013, 09:55:28 pm
« Reply #2 on: December 29, 2005, 12:23:32 pm »
I might have one that size.  Seems like we used one about that size for a PVC drain.  If so, I doubt I'll need it anytime in the next few weeks.  I'll check tonight, and be happy to send it out to ya if I do have one that big.  Your not in St. Louis are ya?
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #3 on: December 29, 2005, 12:41:24 pm »
Another place you might want to check is your local Freecycle chapter. You might be lucky and find someone in your local community would lend you this.
http://www.freecycle.org/
Look to see if your city is there and post the same post you did here.
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
brian23
  • Last login:September 07, 2011, 03:52:01 pm
« Reply #4 on: December 29, 2005, 01:08:30 pm »
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #5 on: December 29, 2005, 04:35:31 pm »
I got something like that from HarborFreight for much less than $25 for a single 3.35" holesaw.  The one I got had three outer cutting tips which would side in and out to make bigger or smaller holes.  Popped it into my cordless drill and cut some ~4" holes for a different application.
If you've got a HF locally, check them out.  I'm pretty sure they've got a multi-holesaw kit for like $5-$8, but I don't think it includes a 3.25".  I think they have one that goes to 3.5" though.
         (bit)
           ||   (arm)
           ||__________||__
                       (cutter)
-- Chad Tower
LPZ
« Reply #6 on: December 29, 2005, 05:06:47 pm »
Thanks for all the help fellas.
Quarterback--Checked the local harbor frieght.  Every size except 3 1/4.
Jabba--Just thought I'd deal with the local BYOAC
LPZ
« Reply #7 on: December 29, 2005, 05:10:47 pm »
Jabba-Wanted to deal with the local BYOAC first.  Since there is an outpouring of help, I'd rather help each other out and throw a bone to a local member for a helping hand.
I will pm lama to get some shipping info for his bit.  It seems interesting to try out and plus it's adjustable for a perfect hole.
Again, thank guys for the quick help.  It's great to deal with a bunch of enthusiasts like myself, that are willing to lend a hand when it's needed.
LPZ
WwonderLlama
  • I _am_ a llama!
« Reply #8 on: December 29, 2005, 05:49:14 pm »
Well, I feel rather sheepish.... If anyone wants to try the tool I used, it's called... <drumroll> a "Circle Cutter" ..... /sigh
So, now you know what to ask for in your hardware store... a "circle cutter" for a drillpress.  :-X
At it once again.
rdagger
« Reply #9 on: December 29, 2005, 07:08:58 pm »
I might be mistaken, but doesn't the Happ 3" trackball require a 3" hole (not 3.25")?
I cut the opening for my 3" Happ with a router (chamfer bit) using an MDF template made with a 3" hole saw.
LPZ
« Reply #10 on: December 29, 2005, 07:45:51 pm »
I tried a 3", but the hole did not accomodate the black case that the ball is in.  I measured with a micrometer, and it comes out to 3.25 to accomodate it.
quarterback
« Reply #11 on: December 29, 2005, 08:39:42 pm »
Sorry, when I said "something like that", I was actually referring to the post that I quoted with the ASCII drawing of a resizable hole cutter.   My HF had a couple of them.  I'll take a pic of the one I bought.
-- Chad Tower
quarterback
« Reply #12 on: December 29, 2005, 08:49:01 pm »
Here's a pic.  Like I said, my HF had a couple different ones.  In my first post I said I got the one with three cutters, but that's incorrect.  I got the one with two cutting blades because mine will cut holes from 1" to 5" in diameter.  The three-bladed one wouldn't do up to 5" and I needed to cut a 4"+ hole.  The one with three blades was actually 'better' because all three blades would extend from a center disc at the same time.   I couldn't find either one on line, but at my HF they were over near all the drill bits and stuff.
Anyway, here's the pic.
-- Chad Tower
