Author Topic: Multi-panel cabinet query.  (Read 820 times)
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
« on: December 23, 2005, 01:57:42 pm »
Just wondering from the guys / gals out there that have multi control panels, how they hook them up.  Do you usually have a separate I-Pac for each panel, or a wiring harness that you unplug / plug into each of your control panels?  If you have pictures, that would be great.
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Multi-panel cabinet query.
« Reply #1 on: December 23, 2005, 02:23:13 pm »
Seperate ipacs would be expensive.
Most use "plugs" like molex connectors, or even Cat 5 cable/jacks.
NO MORE!!
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #2 on: December 23, 2005, 04:07:14 pm »
Where can you buy Molex connectors and the tool to make them?
I b**ch. People listen!!
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« Reply #4 on: December 23, 2005, 06:47:22 pm »
I checked out our local Radio Shacks in Ottawa Canada..... they've all turned into Circuit City The Source...  none had molex connectors.
I had to go to a specialty electronics store.   I paid about 9$ for each 15 circuit molex connector.
I plan on mounting My Ipac in the cabinet and leaving my optipac in the CP with the trackball..
of course, I may never get around to building another CP, but my cab is designed so that I can switch them in and out.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #5 on: December 24, 2005, 01:21:19 am »
You'll get the bug sooner or later!  ;D
It's fast, easy, and cheap to rip a new piece of MDF, blow some holes, wrap it in vinyl, and throw together a new CP with alternate sticks and controllers. Even if you never intend to build another panel, I highly recommend leaving yourself that flexibility. I'm glad I did.
-pmc
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #6 on: December 24, 2005, 01:59:11 am »
Bob Roberts sells Molex, along with pretty much every other connector you might need.
