Main > Main Forum
How do I mount Slikstik Tornado spinner in metal CP?
whammoed:
Why can't you mount it with screws?
I attached mine to a piece of aluminum flat bar and made 4 holes in the flat bar spaced the same distance apart as joystick holes, then mounted it to my cp so the carriage bolts would line up with the joys.
javeryh:
--- Quote from: markrvp on December 22, 2005, 04:22:36 pm ---I feel 100% certain that the double sided tape wouldn't work.
What if you took a couple of pieces of wood and notch them out and glue them to the bottom of the CP with an adhesive that will bond wood & metal.
javeryh:
--- Quote from: whammoed on December 22, 2005, 04:40:59 pm ---Why can't you mount it with screws?
I am covering my CP with a layer of vinyl and I want a clean look - there are black carriage bolts for the joysticks but nothing else. No other real reason I guess...
whammoed:
Gotcha...hope you find a suitable glue.
javeryh:
I'm thinking something like this:
