| Main > Software Forum |
| MameWah vs. GameEx |
| << < (2/2) |
| squirrellydw:
I am new here but doesn't MameWah allow you to pick and choose the games that you want displayed? |
| Roughy:
Yes--you can filter. Actually, if you use the mamewah config tool, it's ridiculously simple. While i'm not an uber-fan of they way they modify some of your file names, I'll be damned if that tool isn't phenominal. Here you go: http://www.bluecamel.org/2005/02/26/mamewah-config-161/ Here's a different version (I've not tried it, but the different options look cool): http://www.mamewah-setup.co.uk/ |
| JonnyBoy:
Yeah, I've been with GameEx since version 1.something and it just keeps getting better and better IMO. Tom did mention he plans on adding the skinning eventually, but he probably wants to get all the kinks worked out of the program itself before doing that big of an overhaul. |
| Necro:
MameWah filtering of lists in the beta is nearly impossible (for consoles) however. Since it doesn't read in GoodCodes, you can't filter based on them, and the lack of catver's for the console roms just makes things nuts. And using the 1.61 setup proggie...well...I'm scared to do that lest it screw up my 1.62 install. |
| squirrellydw:
Does anyone know if GameEX will be able to filter anytime soon? |
| Navigation |
| Message Index |
| Previous page |
