Author Topic: Leaf spring switches...where'd they go?  (Read 6215 times)
Sinner
  • Last login:May 05, 2020, 06:22:06 pm
  • Half the lies they tell about me, aren't true...
    • Geek My Gadget
« on: December 20, 2005, 11:43:35 am »
Why did they stop making leaf spring switches?
It seems that there's a market for them and that most people prefer them.
Why did they go away?
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
Re: Leaf spring switches...where'd they go?
« Reply #1 on: December 20, 2005, 12:33:51 pm »
Doesn't Peale have them for sale?
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
Level42
« Reply #2 on: December 20, 2005, 06:29:04 pm »
How many do you need ? I can get them in any number (reasonably) from Suzo...
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: December 20, 2005, 08:35:53 pm »
Good question... I'd guess the microswitch buttons ended up cheaper and simpler. If you look at the number of parts a microswitch button has: button, nut, switch = 3  Whereas the leaf switches have: button, nut, holder, spacer if needed, switch = 4 or 5.
That's the other thing... the microswitch buttons are "universal". You can install them to metal or thick wood without hassle. For leafs, you need the correct holder or spacers.
NO MORE!!
MikeQ
« Reply #4 on: December 20, 2005, 10:46:20 pm »
I got buttons from Wico and leaf switches and holders from centsible.
I hate micros.  They feel terrible and make too much noise.
erictrumpet
  • Last login:February 17, 2016, 11:59:23 am
« Reply #5 on: December 21, 2005, 12:24:25 am »
I didn't realize leafs were so readily available. All my stuff is micros. I think I might prefer leafs. Do they require a lot more space under the CP? In other words, could I just swap out my micros or will it necessitate a total CP redesign? And does it feel weird to have leaf buttons but micro joys? Or would the leaf-people suggest going leafs on ALL controls?
Eric.
Jabba
  • D-Hutt
« Reply #6 on: December 21, 2005, 01:24:54 am »
Eric.
Once you've tasted from the vine, there's no turning back... ;)
I would replace the joys with Wico Leafs at the same time. Gives the total experience.
Nothing better than being able to "control" the game without a digital 1 or 0 between you...
Redesign: I guess Depends how tightly you've placed your buttons. Leafs DO take up more real estate though...
MikeQ
« Reply #7 on: December 21, 2005, 07:49:06 am »
Eric.
They do take more space.
erictrumpet
« Reply #8 on: December 21, 2005, 10:26:58 am »
Thanks for the replies guys.
Eric.
MaximRecoil
« Reply #9 on: December 21, 2005, 11:39:45 am »
Leaf switches are just as "digital" in nature as microswitches; they are either on or off. If you don't like digital, leaf switches are not the solution; an analog joystick is. Games designed for digital control tend to suck when played with an analog controller though; and vice versa.
Myself, I never cared for leaf switch buttons or joysticks. I like the feedback of a click and it irritates me if it isn't there.
Level42
« Reply #10 on: December 21, 2005, 01:12:13 pm »
Don't think that's what he meant....a microswitch needs a certain amount of pressure to "trip" and make contact. A leaf switch does not have this. I think he meant this with "digital". To me, this is one of the two reasons why leafs are the only way to go. The other is the irritating click, I've hated it ever since I played games.
I still have my trusty FIRST version of my HOME Suzo Competition Pro joystick which I bought for my Atari 2600 way back in 1983. This has leafs for everything. Sadly, Suzo later changed to microswitches.
By the way, despite that I STILL use this stick today AND the leafs are less quality then the true arcade leafs, I've never had to clean or adjust the them.
The rate at which you can fire with a leaf is never matched by a microswitch.
Jabba
  • D-Hutt
« Reply #11 on: December 21, 2005, 01:20:55 pm »
Thats what I meant. Its all about the "feel" for me, and I hate the clickity clackity Micro switches.
Absolutely true. Arcades in my days never had micro switches and that ---smurfy--- clickity clakity cheap feel these MS buttons have.
Jabba
  • D-Hutt
« Reply #12 on: December 21, 2005, 01:23:00 pm »
Hey Level 42, you said you could get these switches. How much per item are they quoting you? I'd be interested in going in on a larger order if the price was right and shipping was decent...
erictrumpet
« Reply #13 on: December 21, 2005, 04:28:24 pm »
Is that why I completely suck ass at Track & Field (I have microswitches currently)? If so, that is a major point in favor of leafs. Even using the "run like hell" dip switch cheat, I barely make it beyond the hurdles. If it's because of the micros, color me a leaf convert!!
Okay so now that we've discussed the pros and cons, where can I buy leaf buttons, 4-way leaf sticks, and 8-way leaf sticks? And do the buttons/sticks come with the leafs or must one acquire those separately and "install" them? Also can someone post pics of leaf switch gear, since I a total leaf newbie.
And don't tell me to search the forums, I'm sure searching on "leaf switch" will return 10,000 results, the best of which is probably this thread anyway. :)
Eric.
MaximRecoil
« Reply #14 on: December 21, 2005, 05:09:35 pm »
Eric.
That doesn't even make sense. The rate at which you can fire is determined by how fast you can tap a button. The minimal resistances we are talking about with leaf springs and microswitches are not enough to slow down the speed at which you can press the button to any measurable degree, or even, at all. Of course, once the switch is closed, the signal is sent to the board at the speed of light regardless of the type of switch.
It may seem faster with one or the other but I think scientific tests would show otherwise. I don't see anyone being able to move fast enough to "outrun" a microswitch. It reminds me of the old claim that you can fire a double action revolver faster than you can an automatic pistol because you have to wait for the slide to cycle in the pistol before you can fire another shot, while the speed of the action in the revolver is determined by how fast you pull the trigger. In reality though, no human is fast enough to outrun the slide of an automatic.
If people were fast enough to outrun a microswitch, people could also outrun a leaf switch, you just need to be faster than a spring.
« Last Edit: December 21, 2005, 05:12:41 pm by MaximRecoil »
Level42
« Reply #15 on: December 21, 2005, 06:24:08 pm »
OK, get a microswitch. Start pushing it very lightly, then slowly increase the pressure. At a certain point (pressure) it will "snap" and make contact....now KEEP IT PRESSED. Next, SLOWLY reduce the pressure...again, it takes quite some time to let it "snap" back into rest position (even so, this release point is at less presure than needed to MAKE the contact).
So, this is actualy what you are doing when pressing a microswitch button when playing a game. Of course, this goes fairly quickly, but never as quickly as possible with a leaf.
One big pro on the leafs has not been mentioned here yet: it is adjustable to your likings ! You can bend (slightly !!!) to a position that you like it to work. Personaly, I like my buttons to make contact VERY early. So, my leafs are already nearly touching eachother when NOT pushed. They only need a little bit of travel of the button to actuate them.
And again, here there is no "pressure point" you need to reach to make the contact. There is only the leaf "spring" resistance, which is very little and the moment you make contact, you get the resistance of the second leaf, IF you push it all the way down (which I don't normaly when playing games like 1942 etc.)
Other people might like to have a long travel and let the contact be made near the lowest (fully pressed) position of the button. (In practice, when rapid firing, a user will keep the button halfway (not release it completely) when it is set up like this.
The thing is, after some time you feel where the leafs make contact.
I also like it that leafs only bend a bit when being pushed. All in all it just feels nicer.
I also wanted leaf joysticks, but they do have some drawbacks, like no availability. There are cheap Chinese made sticks, DO NOT BUY THEME (So called Wico-like on e-bay). If you want a good leaf-stick, try to find original Wico's.
The alternative I choose for are Suzo Inductive joysticks. NO contacts at all (!!) and work fantastic. (Somewhat like the Happ opticals, but with a different approuch. I like the Suzo style more though, because I'm from Europe and grew up with these sticks (again short travel=quick, you need SPEED on your controls if you want to beat a game)....
And yes I can deliver leafs and buttons, and pretty much everything else Suzo sells. For reasonable prices. PM me if you are interesed and what you need.
MaximRecoil
« Reply #16 on: December 21, 2005, 07:02:01 pm »
Yeah, I understand the concept, I just don't believe that people are precise enough or fast enough to realize a difference here. A robot could be programmed to repeatedly press and release a leafswitch button in a manner that when it released it it only released it by the exact amount necessary to open the switch, so that there was less than a hair's width separating the contacts. Now, with a given constant top speed of the robotic arm, it could generate more button presses per second than with a microswitch, because the distance it would have to travel to open and close the switch would be less.
But, in the grand scheme of things, the difference in distance is so small that no one could consistently keep their finger motion/travel in an envelope that is enough to open and close a leaf switch but not enough to open and close a microswitch and at the same time maintain their top button pressing speed.
I would have to see it to believe it (scientific tests).
80sMike
  • Last login:October 23, 2011, 09:16:27 pm
  • I can't play like this?!?
« Reply #17 on: December 21, 2005, 10:01:35 pm »
When I was a kid I was the Track and Field champ at the local Round Table Pizza.  Back then every kid had their own version of the "run like hell" cheat in their back pocket...A trusty hair comb.  There was a way you could use the comb to bridge between the run buttons and if you didn't mash too hard you could run like hell...Nearly twice as fast as the two-handed mashers.
There was another T&F machine at the bowling alley across town that had the leafs adjusted a bit differently so that contact was made with a deeper press, and I consistantly had worse showings.
When I built my first CP I used microswitch buttons and T&F was one of the first games I fired up to see if I still had any skillz.  I raided the medicine cabinet and found an old comb and tried my run like hell technique...Utter disaster.  I felt like a polio victim in leg braces, clickity clickity clacking down the track like Forrest Gump.  Maybe not scientific, but I haven't built another CP with micros... ;D
They may cost 2-3 times as much, but nothing reminds me of the glory days at the old Round Table like leafs.   :)
RayB
  • There's my post
    • RayB.com
« Reply #18 on: December 21, 2005, 10:29:08 pm »
Yeah, and in my opinion it's impossible to beat Sandman in that certain punching game... you know...
With leaf buttons that are finely tuned the way they are supposed to, all you gotta do is alternately bounce your index and middle finger over each button lightly. I'd get insane run speeds with that technique. Can't do that with microswtiches because they require enough force to make the switch click in.
NO MORE!!
MaximRecoil
« Reply #19 on: December 21, 2005, 10:49:07 pm »
Punch-Out is very marathonable; I've never played much past 1.5 million (an hour per million in that game) but the world record is 16 million which is insane considering the game offers pretty much zero opportunity for breaks. SPO = not so easy. The world record for the arcade is a very low 182K or so, and the record for Mame is a much better, but still somewhat low 448K. I'm up to 738K on my machine now and I am right on the verge of being able to marathon it. It certainly keeps you on your toes, a lot more so than Punch-Out which is pretty much an autopilot game once you have the hang of it.
Anyway, special techniques for taking advantage of the faster open/close times of a leaf switch never occurred to me. I was thinking of one button and one finger. Either way, since there have been a couple of testimonials here, I'll take you guys' word for it.
danny_galaga
  • Last login:Yesterday at 09:08:57 pm
    • dans cocktail lounge
« Reply #20 on: December 22, 2005, 01:10:41 am »
sounds like leafs (leaves?) are the way to go. i have microswitches and am happy with them. one advantage of micros is that you can get the switches at any old electronics store for about a buck fifty...
MikeQ
« Reply #21 on: December 22, 2005, 01:32:05 am »
Another problem I've discovered with micros is that the outer ring of the button carries the pressure when you tighten down the nut.  If you tighten them too much, they will cause the laminate on your CPO to separate from the image underneath leaving a ring around the button.  Leafs buttons have little raised plastic ...things as well as a base that fits exactly into a 1 1/8 inch hole.  This puts the pressure on the side wall of the hole rather than the top of the CPO.  Therefore, no rings around the buttons.
erictrumpet
« Reply #22 on: December 22, 2005, 09:49:03 am »
MikeQ I *think* I understand what you are saying but a pic would help... can you (or somebody) post one?
Eric.
Jabba
  • D-Hutt
« Reply #23 on: December 22, 2005, 10:35:23 am »
The only place I've been successful at getting real Wico Leaf style joysticks is from the execellent members here at BYOAC. Post a thread in B/S/T to see if anyone has any they are willing to part with (DOH! blew my source)
« Last Edit: December 22, 2005, 10:37:08 am by Jabba »
MikeQ
« Reply #24 on: December 22, 2005, 11:43:38 am »
Eric.
Micro damaging CPO
Leafs
erictrumpet
« Reply #25 on: December 22, 2005, 11:51:00 am »
Ahhhhhh now I get it. (I didn't know how the leaf button worked, having never seen/handled them). Thanks for the awesome replies and pics fellas :)
Eric.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #26 on: December 22, 2005, 12:36:56 pm »
check your pm's level42!
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
RayB
  • There's my post
    • RayB.com
« Reply #27 on: December 22, 2005, 12:56:12 pm »
Damn! So Mike, where did you CP get printed? You've just added another point to the "plexi over the overlay" camp.
NO MORE!!
MikeQ
« Reply #28 on: December 22, 2005, 01:32:21 pm »
Mamemarquee.com printed my artwork.  I don't really care for the plexi look and now that I know what I'm doing, I would put a little neoprene spacer under the micros and not crank them down so hard.  When I saw what happened, I made sure I didn't tighthen the left side down.  The left side looks fine.  I've been contemplating taking the buttons out and squirting a little glue between the laminate and the art and seeing if I can fix the problem.  It really isn't that noticeable unless you know to look for it.
Quarters
  • Last login:July 08, 2010, 06:53:17 pm
  • I am not now, nor have I ever been, a llama!
    • Quarters Arcade Site
« Reply #29 on: December 22, 2005, 08:19:45 pm »
Hey Jabba, I've got a bunch of Wico sticks in similar condition to yours. If you're ordering replacement switches and buttons maybe we can combine orders to save a few $ shipping and taxes. I'm also in Ottawa
Question: Some of the leaf switches I've found online (like the ones Bob Roberts sells are longer on one side than the other. Can anyone tell me if these are compatible with Wico joysticks or where to get compatible ones?
« Last Edit: December 22, 2005, 08:35:30 pm by Quarters »
97.4 percent of all statistics are full of crap.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #30 on: December 23, 2005, 01:31:15 am »
Centsible Amusements sells leaf parts.
Joystick sized leafswitches
Thin leafswitch holders (wood panel type)
Translucent leaf buttons
Regular Leaf Buttons
Strangely enough, they don't seem to have regular, button-sized leafswitches, just the ones for joysticks- or at least I'm not seeing them.  The ones Quarters is talking about from Bob Roberts, with the one side longer, are the ones for buttons- and no, those don't work with Wico sticks, they're too long.  The ones Centsible sells are the right length, but I notice they don't have the protective white plastic layer, so I don't know if they'll work right with a Wico either.
But you really don't have to replace the leafswitches if they're just a little bent up- just get some needlenose pliers and straighten them out!  Then clean the contact points (pinching a wet business card between the contacts and sliding the card back and forth is the way the operators did it) and you'll find the old ones play just fine.
erictrumpet
« Reply #31 on: December 23, 2005, 02:17:14 am »
I see Centsible Amusements sells leaf joysticks as well -- $10.99, imported from China. Are these any good?
http://www.centsibleamusements.com/index.asp?PageAction=VIEWPROD&ProdID=415
Eric.
Quarters
« Reply #32 on: December 23, 2005, 05:09:36 am »
Thank you  Kremmit.
Good info and link.
RandyT
  • Online Online
  • Last login:Today at 11:44:54 am
    • GroovyGameGear.com
« Reply #33 on: December 23, 2005, 08:27:01 am »
I need to chime in on this one. :)
I built a control panel in the 80's for use with my Coleco and Atari systems.  It used leaf switches for everything because those were all there were at the time, or at least what were commonly used.  They were a serious pain in the ---.   The contacts would corrode.  If you had them set for "hair trigger" that meant that the metal flexed a long way for a full button depress, which led to bent and out of alignment contact points.  After a while, they started clicking because the contact points became almost impossible to keep aligned and they would slide apart and "click" on each button press.
Like Ahigh said, when they are new. they are great.  But my experience was that they weren't like that for long.
Now, about microswitches.  They come in about a hundred different styles when you consider the number of manufacturers there are of these things.  They have varying pressure levels and mechanisms for actuation.  So obviously, you would want to use the ones that most approximate the feel of the leaf.  That means a low actuation pressure and short throw (most of them are short throw.)  So, you say you have that and it's still not as good?  Well, the reason for that is the fact that even the mushiest of microswitches (which seem to be the Cherrys sold by HAPP) require a fair amount of pressure to actuate, more than the average leaf switch which amounts to almost no pressure before actuation.
Which brings us to the solution to the problem (or at least a very good substitute for one.)  The main reason the two feel so different from each other is the fact that one of them has extra spring tension before actuation that the other one does not.  So the solution is to simply remove the spring from the button and let the internal spring of the microswitch do the work.  This also decreases the throw of the button, at least in the case of the HAPP and IL designs, as it eliminates the .030" space between the actuators of the button and microswitch.
It may not be for everyone, but everyone who is not happy with the micros should at least give it a try.  I will never go back to leaf switches after the headaches I had with them.
One last thing; in a game like T&F, where accurate alternation is as important as speed, isn't being able to know for sure that you have made the press, through the tactile feedback and/or "click" of the microswitch, a good  thing?
RandyT
« Last Edit: December 23, 2005, 08:31:40 am by RandyT »
Level42
« Reply #34 on: December 23, 2005, 09:53:17 am »
Eric.
NOOOOOOOOOOOOOO !!! DO NOT BUY THEM !!! They are complete rubbish !!
Check out my (and others
« Last Edit: December 23, 2005, 09:58:47 am by Level42 »
MaximRecoil
« Reply #35 on: December 23, 2005, 10:27:36 am »
I'm no T&F player. We had it down to the laundromat around '84 but after 1 or 2 tries I didn't care for it and much preferred Karate Champ and Punch-Out. But anyway, I have a feeling that people developed a certain technique if they played the same machine long enough and probably any change to the buttons, incuding a new set of leaf springs, or even a readjustment of the existing ones would have thrown them off. So maybe for the people who couldn't do well on T&F when going from leafs to microswitches; the problem wasn't so much the microswitches in and of themselves, but simply the change to something different.
I always hated when anything was changed on a machine that I was already used to. I never cared for any games where rate of fire/button pressing was important so button changes never affected my gameplay much but it certainly irritated me.
thebrownshow
  • Last login:December 14, 2010, 03:14:32 pm
« Reply #36 on: December 23, 2005, 10:44:03 am »
Has anyone else actually done this?  Sounds like an interesting theory.
erictrumpet
« Reply #37 on: December 23, 2005, 10:47:31 am »
I must admit when I first got into mame and bought my first controls, I was in love with the microswitches. Yes the clicked, but to me the reliability was worth it. The click doesn't really bother me anyway, since I am wailing on the buttons so hard and screaming at the game so loudly that a little extra clicky sound is not even heard. :) Anyway, my favorite game back in the day (and still today) is Galaga, and I used to know which machines in town had "a good fire button" or a "bad" one. Well, microswitches changes all that. All the buttons on my CP feel exactly the same, no adjustment necessary, and they will never change or wear out. I kinda feel the same way about my monitor; I use a PC monitor, and I apply scanlines and vector flicker and stuff like that to give it the old look, but overall I prefer the modern, cleaner look. So maybe microswitches are okay. Not all modern advancements are bad. I mean, do any of you guys still use rotary phones for the tactile satisfaction of turning the dial to call your mother? :)
Eric.
Jabba
  • D-Hutt
« Reply #38 on: December 23, 2005, 10:52:32 am »
Yeah, I'm not exactly which spring to remove. Do you open up the Micro Switch?
« Last Edit: December 23, 2005, 10:55:00 am by Jabba »
Jabba
  • D-Hutt
« Reply #39 on: December 23, 2005, 10:54:20 am »
Uhhhh, yeah! Do you have a problem with that ?  ;)
