Author Topic: what fornt end and emulators to use?  (Read 2066 times)
mrynit
  • Last login:May 13, 2006, 06:01:12 am
« on: December 19, 2005, 02:12:33 am »
the computer i want to use for my arcade is an old Compaq. it has a P3 667MHz with 320MB of PC100 RAM and it has an AGP 2x 8MB savage GT video card. i want to use usb gamepads and rewire them to joystics and buttons. I want to have nes and snes games mainly and possibly Atari or other consoles games. what emulators should i use? i do not want the player to use the keyboard or mouse to switch games, just use the joystick and buttons. what front end would i use then?
danny_galaga
  • Last login:May 05, 2024, 10:35:21 pm
    • dans cocktail lounge
Re: what fornt end and emulators to use?
« Reply #1 on: December 19, 2005, 03:35:35 am »
welcome to the forums! it will all depend on what sort of OS you use and how capable YOU are. im not that capable myself  :-[  see:
http://forum.arcadecontrols.com/index.php?topic=47246.0
the two ive tried myself are ultrastyle and atomicfe. both set up fairly easily (atomic maybe a bit quicker, but some of the french instructions confue me). atomic is supposed to work with win98 although i havent tried it. atomic also works for all sorts of emulators. ultrastyle i couldnt make work with win98, so maybe xp only? others here will tell you about other front ends, my perspective is of someone not really confident with software...
  • Last login:May 03, 2024, 11:58:33 pm
« Reply #2 on: December 19, 2005, 03:37:41 am »
you need a new pc
While mame runs in dos, most console emus dont and with a pc that puny you'd be better off running dos (mostly because of the lack of ram).
mrynit
« Reply #3 on: December 19, 2005, 04:48:45 am »
OK...what would work with the computer i have now? anything? I want to go with usb controls. i dont get why mame needs so much power. ZSNES works fine on that computer.
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #4 on: December 19, 2005, 05:53:02 am »
zsnes is not mame.
jhanson
« Reply #5 on: December 19, 2005, 08:10:09 am »
Older versions of MAME will run fine on that machine, at least in DOS.  I'd recommend using MAME 0.55 - 0.78 on a machine like that.  However, if you're planning to use Windows so you'll have USB support, I'd stick to the lower end of the MAME version range I gave.
As for front ends, I like AdvanceMenu in DOS, but it's a pain to configure.  Another good but simple one is GameLauncher.  In Windows, I like how customizable Dragon King is, but I'm not sure it would run well on that PC.  MameWAH is the popular choice, but I've yet to figure out why.
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #6 on: December 19, 2005, 08:30:18 am »
Yes, you can use old version of mame .
And  XP and Atomic Fe on your configuration.
My Test/Dev computer for AtomicFE is on a old celeron 533Mhz 256Meg RAM  and an old ATI card.
It runs under Windows XP , FastMame 0.71 and Atomic FE.
Of course i can not run recent 3d games, but for game i like  , like Donkey Kong, Galaxian , Pacman..etc.. it is very good.
mrynit
« Reply #7 on: December 19, 2005, 02:55:31 pm »
And
« Last Edit: December 19, 2005, 03:02:40 pm by mrynit »
« Reply #8 on: December 20, 2005, 12:17:38 am »
youki
    • Atomic Front End
« Reply #9 on: December 20, 2005, 03:45:21 am »
will i still have usb support?
Yes.
the games i want to play are nes snes. all i need is  FastMame 0.71?
To play nes and Snes games you need a nes and Snes emulator , you can not play nes games with mame.
mrynit
« Reply #10 on: December 20, 2005, 05:17:00 am »
i ment to say Atomic FE. what i want is MAME, ZSNES and some nes emulator all to work with a front end that uses only jpystick and a few buttons, no keyboard interface after it has been set up. so my question to you(all) what front end do i use to run the above stated emulators? i hear MameWah will run any emulator. but will MAME32 run the above stated emulators?
sorry for getting off the subject of this post.
youki
    • Atomic Front End
« Reply #11 on: December 20, 2005, 05:30:31 am »
AtomicFE can work only with a joystick and few button. No need keyboard interface.
Anyway, even if a Front End need a keyboard interface and you don't want use it, you can use something like JoyToKey.  This driver will convert joystick input to keyboard input.
I don't  think that in MAME32 you can use "external" emulator. It is only the build'in Mame.
mrynit
« Reply #12 on: December 20, 2005, 04:18:32 pm »
just to clarify, mame32 is a FE and an emulator, which only runs arcade roms
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: December 21, 2005, 10:52:17 am »
To be technical - MAME32 is the Windows MAME port with a built-in GUI, which only runs arcade roms.
Based on your other posts, you want an older version 0.55 or so of Command-line MAME, ZSNES, Ultra FCE, and Atomic FE to launch any of them.
Tiger-Heli
    • Tiger-Heli
« Reply #14 on: December 21, 2005, 10:59:40 am »
Also - you do NOT need to upgrade hardware.
I played older MAME games on a Pentium 200MMX for many years.
mrynit
« Reply #15 on: December 21, 2005, 03:24:26 pm »
the computer i'm using is really a 450mhz 100mhz FBS P3 with 192RAM. i tried playing SF2 with MAME and it worked fine for the most part but when some characters jump is slows down. i guess it wil work for older games but for some snes based arcade games it may run slowly. i know with ZSNES running it on that computer above would not be aproblem. i havent tried MameWah on it yet but i think it will work. i am a bit more inclinde to get a different computer. some thing like an AMD Athlon XP 2200. the problem is i cant find any.
Tiger-Heli
    • Tiger-Heli
« Reply #16 on: December 21, 2005, 04:00:40 pm »
I think you will find SF2 in MAME more demanding than ZSNES - You also can tweak the settings to speed MAME up somewhat.  Mamewah or your frontend shouldn't be a problem.
mrynit
« Reply #17 on: December 22, 2005, 08:34:34 pm »
how do you tweak MAME to make it run faster?
Tiger-Heli
    • Tiger-Heli
« Reply #18 on: December 27, 2005, 01:26:57 pm »
Increase Frameskip, decrease audio samplerate, change to lower resolution, experiment with D3D settings, etc.
highland04
  • Last login:April 21, 2012, 01:46:00 am
« Reply #19 on: December 28, 2005, 12:15:34 am »
to bluntly say that he needs a new computer is inaccurate.
mame will run on a 400mhz pc.
i ran nesticle on a 233mhz pc, snes9x on a 600mhz pc.
you dont need a new pc, you just need to look for the best compatibility.
« Last Edit: December 28, 2005, 12:18:57 am by highland04 »
brophog
« Reply #20 on: December 28, 2005, 04:37:34 am »
You're comparing a single console emu to a multiple hardware emu. Apples and Oranges.
More correct may be to say that it's not necessary to play MAME on a 400 mhz machine.
jhanson
« Reply #21 on: December 28, 2005, 07:51:14 am »
What version of MAME are you using?  If you go to .36 or .55, a 450mhz machine should play a game like SF2 fine.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #22 on: December 28, 2005, 12:01:50 pm »
I agree with the last poster. 0.78 is a little too high a version for that CPU. I use 0.78 on 1 ghz, but without "triplebuffer" and "wait for vsync" turned off (that means I get tearing in scrolling games). For vector games, I still use 0.55 because .78 won't run them at full frame rate on even a 1ghz!
NO MORE!!
