Author Topic: Routing options  (Read 1135 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Routing options
« on: December 18, 2005, 03:39:21 pm »
Is there a way to "route" without an actual router?
Here's my dilemma: I own a regular black n decker router, but it's too big and powerful for small precise jobs.
I also own a Dremel. I bought the Dremel router kit, but whatta ya know, my model is too small for it.
So what can I do? I want to route out about 1/16" to 1/8" of an area in a precise rectangle.
NO MORE!!
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: Routing options
« Reply #1 on: December 18, 2005, 08:20:54 pm »
Sounds like its time to drill a hole and then chisel out the edges.  Thats a tiny rectangle.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Re: Routing options
« Reply #2 on: December 18, 2005, 10:33:26 pm »
Take that Dremel kit back and use the money to buy a laminate trim router.  They'll handle the smaller-shanked bits and work perfectly for what you're talking about.
Alternately, you can clamp up some 2x4's to either side of the hole you want to route to give your router base something more stable to ride on while you route
DrewKaree
  • HAH! Nice one!
Re: Routing options
« Reply #3 on: December 18, 2005, 10:41:28 pm »
Ryobi makes a cordless one as well, but having to buy the batteries and charger will end up making it more expensive than these if you don't own any of their stuff, plus other than Porter Cable, I wouldn't expect much battery life out of a cordless router.  Home Depot carries any of these:
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
Re: Routing options
« Reply #4 on: December 18, 2005, 10:55:03 pm »
I'd use a small sharp chisel assuming you don't need to bore a square all the way through the board, just a recessed bit for a square screw hole, etc...
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
bb040
  • Last login:December 17, 2020, 03:11:01 pm
  • ok what ever
Re: Routing options
« Reply #5 on: December 18, 2005, 11:13:25 pm »
you might try a roto zip...
Avery
  • Last login:May 03, 2013, 12:52:02 am
  • Have fun! Make stuff.
Re: Routing options
« Reply #6 on: December 19, 2005, 06:55:25 pm »
There is a trick they used to do for decorative metal inlay where they would make sheet metal stencil, fasten that down and then hit the wood with a litte fork like dubus mounted in a drill press (think really agresive wire brush).
I don't know if this would work for you, but you're talking about such a small area....
If you only hava a couple of these to do, I'd carve them out with an Xacto knife.
Avery
DrewKaree
  • HAH! Nice one!
Re: Routing options
« Reply #7 on: December 19, 2005, 07:28:36 pm »
I think you're talking about a needle scaler
Avery
Re: Routing options
« Reply #8 on: December 20, 2005, 12:12:21 pm »
No, it definitly spun, that way you could control the depth of cut.
I read about this somewhere, I think in a book on old tools.  I don't know if anybody is doing this sort of thing any more or if they've even done it for the past 50 years.   I just threw it out there in case it gave Ray some flash of inspiration.
Avery
