May 08, 2024, 11:10:32 am
It designed to set 5 different output value groups at the same time; every output value set can program 10 types coins.Different output values mean number of output pulse.
Deposit the coins in turn. you can program up to 10 coins. If less than 10 coins can add and store later. For example you can prepare 10 quarters as diffferent condition as possible. Or you can deposit 10 same or different tokens.
looks the same as the WEI-YA mechs that Ultimarc sell. Which work very well with BYOAC tokens Just fit the type of coin you want to use in the back of the mech and it compares the ones going in. That's if it is the comparative type.
