Main > Main Forum
Replacing Joystick Microswitches?
daywane:
the Chery switch will fit but not work right.
the joysticks poneyboy sells have the same switches.
I broke 2 of mine and asked for help from him.
He said they were a bear to find.
maybe he has a contact for them now? still waiting for mine to show up in the mail. should be any day now.
Do Not Over Tighten.
Will crack switch
hatrick:
--- Quote from: Jabba on December 14, 2005, 08:47:11 pm ---
Jabba...what's the sheet metal strip on the bottom of your joystick for?
Jabba:
--- Quote from: hatrick on December 15, 2005, 03:59:47 pm ---
This is used to "switch" the 4 way 8 way switch on the joystick. I moved it to the right for the picture. It is normally on the left. When you lift the joystick handle up (from on top), it allows you to switch the joystick between 4 way 8 way mode. The white rounded switch is what gets moved...Make sense?
See pic C) for white rounded switch
daywane:
none of my switchable has that ( marked in black)
Jabba:
When I bought them back in 2004, I remember they were coming out with a new version of the joystick. That ? part is used to move that switch there in C). Pain in the ass to wire around though!
