Author Topic: Noob MAME question  (Read 661 times)
spuddybuddy
  • Last login:December 28, 2005, 01:35:46 pm
  • First Cab progess - 0%
    • MAME Arcade Details
Noob MAME question
« on: December 11, 2005, 12:13:49 am »
Well I plan on building my first cab in January so I downloaded MAME, but I dont know how it exactly works. Do I download a frontend the runs MAME for me? And also what is MAME-WAH is it a frontend???
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
Re: Noob MAME question
« Reply #1 on: December 11, 2005, 12:45:22 am »
There is a version of MAME with a built in frontend called MAME32 otherwise you can download one of the command line versions of MAME that you would need a front end for.  MameWah is a front end (actually the one I use for my cabinet) and there are a vast assortment of other good frontends out there to use too.  The advantage of having a front end is that you can customize it practically any way you want.  Where MAME32 will not let you customize it's built in frontend.
loadman
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
« Reply #2 on: December 11, 2005, 01:15:51 am »
Yeah Mame32 is the way to go for a New user..
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #3 on: December 11, 2005, 03:45:06 am »
But not necessarily a new cabinet user. In reality, someone going to take the time building a cabinet needs to get accustomed to the software months in advance of building something like this.
Mame32 is nice and noob friendly, but almost any FE is better put into a cabinet. You can get by with Mame32 in a cabinet, but you'll be happier using a real FE.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #4 on: December 11, 2005, 04:50:53 am »
Man, how many memories reading this thread has brought up. ::)  I second learning how to work a frontend as well.  I would install the microsoft toy that allows you to right click a folder and have the option to open a command prompt there.  That way you can test mame.  Once you feel you get mame set up, this little tool is nice to have to test.  You can find a link at TigerHeli's site, but it is on the microsoft site.  By the way, be prepared to be overwhelmed for a little bit untill you get it figured out.  It's worth it!!!
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: December 12, 2005, 06:48:07 am »
