Main > Main Forum
Coin Doors
Pages: << < (3/3)
RetroACTIVE:
I got the 4 player version...
You can actually make your own coin box out of wood and just place it under the coin door mechs... it will give you the same "ker-plunk" effect you want.
I would do it that way now if I were to do it over... it is not worth the xtra cost for the bracket and box.
brian23:
How to wire your coin door:
http://www.retroblast.com/articles/coindoor.html
Happ Part #'s:
Wedge socket for LEDs:
 42-0351-00 LAMPHOLDER,F/PLASTIC MECH HOLDER
LED for for Wedge socket:
 91-10WB-123R LED T3 1/4 WEDGE BASE 12VDC 3 CHIP RED
good luck!
Roughy:
Okay, so with the above and the 2 player door identified by Mameroom, I should be good to go?
If so, very, very cool--and thanks!
Flinkly:
uh, i'm not sure about those lightts...mine came with sockets and lights i think, so it should include that.  as for buying the lights anyways, you can get them at any auto parts store so don't buy them from happs, cause i'm sure they are twice as expensive.
RetroACTIVE:
--- Quote ---uh, i'm not sure about those lights...mine came with sockets and lights i think
Roughy,
Mine came with sockets and lamps as well... only problem is the lamps are 14 volt rated.  They are not so bright when hooked up to a 12 volt PC power supply.  I changed them out for super bright leds and WOAH what a diff.  I bought both red and blue... my cab is blue and black so the blue looked great.
FYI:
http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=CAR
WLED 4-LED bulb
12VDC 4-LED Wedge Base Bulb (194/168 type)
Have Fun!
Pages: << < (3/3)
Go to full version
