Author Topic: Do you unplug your arcade monitor when you shut down your computer ?  (Read 747 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
Hi. I am thinking about replacing my pc monitor with an arcade monitor. Do you guys unplug your monitor when your computer is turned off or is it ok to leave them plugged in ?
thanks.
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
Re: Do you unplug your arcade monitor when you shut down your computer ?
« Reply #1 on: December 07, 2005, 08:48:16 am »
I think you will find most people use something like this:
http://www.bitsltd.net/SmartStrip/
Happy Gaming!
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: December 07, 2005, 01:02:34 pm »
Yes, you should not leave it powered up.
How you go about un-powering it is... up to you. Easiest way would be to have everything plugged into a power bar.
NO MORE!!
  • Last login:May 06, 2024, 04:31:28 pm
« Reply #3 on: December 07, 2005, 01:34:38 pm »
This is what I'm going to be using.  It just arrived in the mail yesterday!
big daddy
  • Last login:May 01, 2019, 12:16:13 pm
« Reply #4 on: December 07, 2005, 03:16:58 pm »
does the power strip protect adequately against surges?  I have a $400+ betson and can't afford to lose it.  I currently have a surge protector with over 3000 joules I believe which has a warranty if you lose equiptment plugged into it.    My main worry has been whether the power strip would have the same protection
RayB
  • There's my post
    • RayB.com
« Reply #5 on: December 07, 2005, 08:13:26 pm »
If you're worried, add a fuse to the power line.
NO MORE!!
Bones
  • [Moderator]
« Reply #6 on: December 07, 2005, 09:14:10 pm »
Plug the smartstrip into your surge protector!
