Author Topic: Suck  (Read 1323 times)
Bones
  • [Moderator]
Suck
« on: December 06, 2005, 03:40:53 pm »
I have mounted two 120mm (5
Stingray
Re: Suck?n?blow. Cooling cabs and dust build up.
« Reply #1 on: December 06, 2005, 04:46:06 pm »
I have no idea. I only came in here because of the title. Dissapointment is something I'm going to have to learn to live with.
-S
hnugz
  • Last login:September 14, 2013, 06:18:38 pm
    • Horrorcore Games
Re: Suck
« Reply #2 on: December 06, 2005, 04:47:56 pm »
So in other words the bottom of the cabinet is open and the top blows air out?
I wouldn't worry too much about getting a bunch of dust in there.
"Don't play pinball if you only got one arm, cuz your score will suck."
ahofle
    • Arcade Ambience Project
« Reply #3 on: December 06, 2005, 04:58:08 pm »
-S
LOL
Thx for making me spit coke on my keyboard.
Bones
  • [Moderator]
Re: Suck
« Reply #4 on: December 06, 2005, 05:24:01 pm »
Yes the top and bottom are open, but the extraction fans are mounted somewhere in between. In the openings there is no direct extraction or exhaust system, it is more about letting nature doing its thing with hot air rising and cooler air entering the cab down lower.
hnugz
    • Horrorcore Games
Re: Suck
« Reply #5 on: December 06, 2005, 05:29:13 pm »
Honestly with having both the top and bottom open I would be really surprised to see a noticeable temp difference between having the fans on and having them off.  If things are closed in, there is something to pull the air from.  when it is all open, it is pulling air from everywhere.
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
  • Last login:May 23, 2021, 12:53:30 pm
« Reply #6 on: December 06, 2005, 06:20:41 pm »
-S
LOL
Caution neverdrink liquids and view a Stingray post
Bones
  • [Moderator]
Re: Suck
« Reply #7 on: December 06, 2005, 06:24:41 pm »
It is not uncommon here for the temp to hit 105 in summer so keeping things as cool as possible became a high priority.
Even if the fans have little to no effect I think the added security is good for piece of mind!
hnugz
    • Horrorcore Games
Re: Suck
« Reply #8 on: December 06, 2005, 06:29:26 pm »
Bumblebounces
  • Last login:January 26, 2016, 07:57:28 pm
  • I ever tell ya 'bout Bumbles? Bumbles...BOUNCE!
    • Starbase 74
Re: Suck
« Reply #9 on: December 06, 2005, 06:53:15 pm »
Are people installing filters around air inlets or just living with the normal dust build and performing regular cleaning maintenance?
I actually designed this function as part of my jukebox.  Except, I took another angle on it.  The fans are at the bottom of the cab drawing airflow down, with the filter at the top.  This is backwards as heat rises but I was thinking of all the times when the juke isn't running.  If the fans are at the top and not running, that leaves holes to allow dust to settle in through the fan vents.  By placing the fans at the bottom, drwaing air down through a filter (which is the entire top of the cab, by the way), it allows airflow for heat disapation while running and allows dust to settle on the filter when not running.  That keeps all the dust OUT of the cab.
Bumble
« Last Edit: December 06, 2005, 06:55:04 pm by Bumblebounces »
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
Re: Suck
« Reply #10 on: December 06, 2005, 07:10:15 pm »
Why not just have top fans and bottom fans that BOTH blow air out? It's not like they're going to create a vaccuum or something. Might just help keep the dust particles closer to the fans rather than depositing them on the components.
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
Re: Suck
« Reply #11 on: December 06, 2005, 08:09:18 pm »
It could suck the monitor right into the cab!!!!!!!!
-- Chad Tower
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
Re: Suck
« Reply #12 on: December 06, 2005, 09:19:08 pm »
I have learned to hate the fans I have mounted to my Mame cabinet. They are noisy! Testing has shown little difference in temps in the cabinet, so I unplugged them.
YMMV
Bones
  • [Moderator]
Re: Suck
« Reply #13 on: December 06, 2005, 10:30:31 pm »
Interesting.
As you may have read in my thread, my original plan was never to have them hence the open areas at the top and bottom of my original design. The addition of the fans at a later stage was mostly the result of fear, fear of baking my expensive monitor without them......
I may just run my own tests, it certainly wouldn't hurt.
LPZ
  • Last login:April 11, 2015, 01:55:21 pm
  • 2nd place is the first loser!
Re: Suck
« Reply #14 on: December 06, 2005, 10:34:29 pm »
I am glad I don't have temp problems with my cab.  I keep my cab in the garage and 3 of the 4 wall are backfilled with dirt.  It's almost like a coal mine.  VERY cool in the summer and PRETTY darn warm in the winter(compared to the outside temp).  I have some extra 80-120mm fans lying around, but never had a reason to use them.
Dual 50 Caliber Continuous Fire Leon Type Machine Guns......OH YEAH!!!!!
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Re: Suck
« Reply #15 on: December 07, 2005, 06:15:09 am »
I have a solution to your problem, so you can take those 2 fans back.  Remove the lower panel in the back of your cab.  Somehow, fashion a bracket to install the fan shown below.  This will take care of both your heat AND dust problems, and perhaps any frilly knick knacks the missus will have had lying around the house.
Payment may be rendered in cash only, and you're welcome.  My work here is done ;D
Ed_McCarron
Re: Suck
« Reply #16 on: December 07, 2005, 08:02:55 am »
Since it looks like a wide notch acreoss the width of your cab thats the 'intake' , perhaps buy a large, home, forced air heat type filter.  The big, woven ones.  Shouldn't cost more than a buck or 3.
Cut to fit across the notches (inside) and hold in place with a few staples.
SirPeale
  • Green Mountain Man
Re: Suck
« Reply #17 on: December 07, 2005, 08:33:23 am »
It's just something you're going to have to deal with.  General maintenance on your machines to keep them running okay.  Dust control is part of that.  Vacuum the machine out at least once a month under heavy use.  Less with less use, of course.
nostrebor
  • SHOCKING!!
Re: Suck
« Reply #18 on: December 07, 2005, 10:10:03 am »
If you think about it, those monitors were designed to be enclosed in a cabinet/kiosk, sandwiched inbetween many other hot games, and run almost 24/7. Many arcades back in the day were not or poorly conditioned, and packed full of people. = HOT
I would imagine that the slot at the top and bottom of your monitor area is double the cooling area needed by design for that monitor, and you will be running the unit about 1/4 of the time it was intended to be run.
Still, testing is not going to hurt anything.
DrewKaree
  • HAH! Nice one!
Re: Suck
« Reply #19 on: December 07, 2005, 11:52:16 am »
I gotta say I disagree with these words.  I think they tried to design as much cooling into them as possible, but they didn't put THAT much effort into it.  True, they WERE designed to be put into a cab/kiosk, but they ALSO had to design those enclosures with as little access to the innards as possible, lest some ass hat without his helmet that day decide to see if he could get something for free by tinkering with the innards.....ZZZTTTTZZZTTTT!
I think they put as much thought into designing heat control into the enclosures as they did to what color they'd make the thing.
We also have the added benefit of hindsight and being able to learn and improve on the heat control, so why not overengineer the thing to make OUR stuff last longer?  To an op, it'd suck to have something go down due to heat issues, but almost without a doubt, he'd have a replacement readily available.  We often have to come up with the cash to buy a replacement part, and in some cases, it'd take several weeks to get the cash and the part, so I say the heck with it.  Overengineer the snot out of it.  Throw a low-noise bathroom exhaust fan into the top of the thing!
nostrebor
  • SHOCKING!!
Re: Suck
« Reply #20 on: December 07, 2005, 12:07:08 pm »
Actually, this is my point. The monitors were coming off of lines for things other than arcade games back in the day. The monitor designers were not even sure of what application their units would be put into. With this in mind, the designers are forced to design for worst case scenario, or to standards handed down to them, which are usually quite strict. They were then put into a cabinet that was designed for security, as you stated, and cooling was an afterthought at best.
Bones cabinet has considerably more passive cooling allowance, than even the best of the industry cabinets. His monitor is brand new. It is also a product of 20 plus years of design for the industry, with many previous mistakes to help refine the design needs. This does not take into account the improved manufacturing processes for components and PCBs that have occurred in the last 20.
With all this in mind, mnay of the original monitors have lasted untouched, for over 20 years, without any particular care given to their needs. I would expect a modern home use monitor to last for many years based on the conditions the old industry monitors have withstood.
Of course, it wasn't my hard earned cash that bought it, so I still believe testing is in order.
DrewKaree
  • HAH! Nice one!
Re: Suck
« Reply #21 on: December 07, 2005, 12:42:32 pm »
I think we can all see I didn't get that at all :-[
BobA
  • What Me Worry?
Re: Suck
« Reply #22 on: December 07, 2005, 12:53:58 pm »
If you turn your fans around so they blow into the cab they will be easy to put filters on.  Then the fan will pressurize the cab and minimal dirt should come in the existing openings.
DrewKaree
  • HAH! Nice one!
Re: Suck
« Reply #23 on: December 07, 2005, 02:35:58 pm »
My fan suggestion should blow anything in, around, and through the cab ;D
And as added incentive, Bones can have parties and tell all the women that skirts are the attire they are to come in, then have them play the cab.  It then becomes an even BETTER male entertainment center!  w00t!
nostrebor
  • SHOCKING!!
Re: Suck
« Reply #24 on: December 07, 2005, 03:22:25 pm »
Drew's new line of reasoning has caused me to reconsider my NO vote for fans on your arcade cabinet.
DrewKaree
  • HAH! Nice one!
Re: Suck
« Reply #25 on: December 07, 2005, 03:26:08 pm »
I think I may have inspired Stingray to add more fans too now!  Score!  He's gonna pass ME!
Stingray
« Reply #26 on: December 07, 2005, 03:32:22 pm »
You have to be kidding. Fans? I just leave the back door off. You're a closet go-getter. ;)
-S
DrewKaree
  • HAH! Nice one!
« Reply #27 on: December 07, 2005, 03:38:45 pm »
-S
Then you've actually prepped your cab for the fan I posted!  Stop throwing shiny objects in the other direction to distract everyone!
Besides, if I come out of the closet, the RNC knocks on my door and takes back their card.
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
Re: Suck
« Reply #28 on: December 07, 2005, 04:18:47 pm »
Its more effective to have cold air blown in.
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
Kremmit
  • - AHOTW -
  • Who the heck is that?
danny_galaga
  • Last login:Yesterday at 09:08:57 pm
    • dans cocktail lounge
Re: Suck
« Reply #30 on: December 08, 2005, 05:31:15 am »
"It should suck, not blow"
- James Spangler, inventor of the electric vacuum cleaner.
Lilwolf
Re: Suck
« Reply #31 on: December 08, 2005, 08:31:58 am »
btw, I found that it was MUCH more efficeint to blow air right down on my processor.  I had a decent fan that can move air, that goes into some old plastic dryer duct (but I had to replace it with the flexable gutter accordian things... I don't think its as good).  And then place that right over the processor.
But that is the only thing I had real probles with heat...
Then having good air slots at the top should do... heat rises... and it will continue up if its able to... I don't think you need to extra fans to draw it out... it should do it on its own (if enought slots that is).
DrewKaree
  • HAH! Nice one!
Re: Suck
« Reply #32 on: December 08, 2005, 10:47:18 am »
If Bones doesn't have a steady supplier of dry ice to use in cooling his machine, well then he's just a straight wanker.
End of story
Ed_McCarron
Re: Suck
« Reply #33 on: December 08, 2005, 11:24:27 am »
Just make sure noone flips the big switch that changes it from 'suck' to 'blow'.
Orclord
  • Last login:October 16, 2009, 03:09:38 pm
Re: Suck
« Reply #34 on: December 08, 2005, 04:17:24 pm »
Been looking for that switch on the GF.....
elvis
  • Last login:April 13, 2023, 05:31:03 pm
  • penguin poker
    • StickFreaks
Re: Suck
« Reply #35 on: December 08, 2005, 08:10:09 pm »
Avoiding dust is easy.  You need two things:
1) Positive pressure: ie: all airflow in is greater than all airflow out.  If you have negative air pressure (ie: a vacuum) then air starts creeping in from places you don't want.  Make sure to take into consideration dust filters when measuring airflow.
2) Dust filters.  Some fan manufacturers make nice snap-on dust filter gizmos that are easy to remove and clean when they get grubby.  If the fan isn't visible or you don't care about aesthetics, a thin cleaning cloth (we call them "chux" here) can be used as a great cheap disposable dust filter.
Put 1 and 2 together, and your cabs (or computers for that matter) will stay dust free.
