Author Topic: Trying to mount T-Stik in a metal CP?  (Read 1131 times)
  • Last login:May 06, 2024, 04:31:28 pm
« on: December 02, 2005, 12:51:52 pm »
I want to install my T-Stiks in my CPs but I'm not sure what type of hardware to use.  I'm envisioning some sort of bolt with a semi-spherical head but I'm not sure what they are called or where to get them.  Does anyone know what I'm talking about?
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
Re: Trying to mount T-Stik in a metal CP?
« Reply #1 on: December 02, 2005, 12:55:27 pm »
Yeah, thy're called carriage bolts...
http://images.google.ca/images?hl=en&q=carriage%20bolt&sa=N&tab=wi
You can get them at HD. I think 1/4" diameter should do it, but go in to Home Depot with the the mounting plate and get one that fits. In a metal panel, should not need anything more than 1/2" to 3/4"...
I painted the top of my bolts black with blak enamel pain you get from a hobby shop...
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
« Reply #2 on: December 02, 2005, 02:43:16 pm »
I've had trouble getting the correct sized carriage bolts at Home Depot in the past. When in doubt, you can order them online.
« Reply #3 on: December 02, 2005, 02:43:52 pm »
« Reply #4 on: December 02, 2005, 02:45:38 pm »
Thanks - I see that Happs carries these things but I would have no idea what size to get (also you have to order 100 of them)...
Jabba
  • D-Hutt
« Reply #5 on: December 02, 2005, 03:11:09 pm »
I looked at my website where I documented my build. From it I foiund this...
I used the 1/4" to cut the holes for the carriage bolts as I am using 1 and 1/2 inch 1/4 carriage bolts to mount the joystick to the CP.   (my CP was 3/4" MDF...).
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #6 on: December 02, 2005, 07:32:43 pm »
i'm also looking for a black piano hionge but I can't find it anywhere.  I'm not sure how paint would adhere to that though with all the movement...
I had the same problem ... ended up buying brass (was on sale), then roughed it up a bit with with wire brush attachment on the dremel, wiped it down, then primed and finished with spray paint. I kept the coats very light and moved the hinge after each coat. No problems to date, but then I haven't opened any of those panels much.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
« Reply #7 on: December 03, 2005, 09:04:50 am »
