Author Topic: how do I hook this trackball up to a computer?  (Read 1373 times)
unix4hire
  • Last login:October 16, 2008, 06:12:47 pm
  • activate interlocks...
    • My Business
« on: December 02, 2005, 01:43:40 am »
 ???  It came out of an old bowling game but rolls pretty good.  How do I connect this sucker?
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 08:37:55 pm
Re: how do I hook this trackball up to a computer?
« Reply #1 on: December 02, 2005, 06:50:08 am »
Opti-pac or hack it to plug into Ps2 port (use ps2 mouse).
Free VGA Breakout Cable
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #2 on: December 02, 2005, 07:31:43 am »
To connect it to the Opti-Pac, you'll need to cut off that Molex connector (or make a harness with a female molex ), then wire it to the Opti-Pac.
The Opti-Pac has 4 screw connections for a Trackball
« Last Edit: December 02, 2005, 08:27:55 am by Jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
unix4hire
    • My Business
« Reply #3 on: December 02, 2005, 01:10:41 pm »
I was thinking this is the way to go but got a little hestitant when I took it apart to examine.  Basically would I be replacing the entire "mouse" itself with the trackball unit, and reconnecting the cables?  I didn't know what order to connect each one as.  I'll have to hunt for a nice link on doing this.  trial/error
no it doesn't light up.
what's the recommended way then (i.e. the easiest), optipac or ps2 hack?
vader
  • Last login:September 23, 2022, 12:22:08 pm
  • I can't breathe in this thing !!
« Reply #4 on: December 02, 2005, 02:40:26 pm »
Did I miss something, where's Oscar
tim
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
« Reply #5 on: December 02, 2005, 02:41:36 pm »
Easiest? Optipac... unless you're a whiz at soldering, then ps2 hack.
Optipac- easy, can handle 2 trackballs, 4 spinners, reasonably priced, but not cheap.
ps2 hack= 1 trackball, cheap.. may already have a mouse lying around.
mahuti
« Reply #6 on: December 02, 2005, 02:42:14 pm »
Oscar has other commitments with "Real Life"
http://www.oscarcontrols.com/
has been offline for months now.
vader
« Reply #7 on: December 02, 2005, 02:45:53 pm »
Thats unfortunate, I just searched and read some past posts that he how other things to take care of.  Hope all returns to normal for him.
Tim
Jabba
  • D-Hutt
« Reply #8 on: December 02, 2005, 03:06:51 pm »
I agree with mahuti, Optipac easiest, but most costly. Viable if you wanted to put more than 1 PS/2 device on the computer...Otherewise, Mouse hack is good. I thought Oscar had the mouse hack documented on his site somewhere. Searching here will definately bring it up...
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
« Reply #9 on: December 02, 2005, 03:16:34 pm »
It's not that hard to hack to a usb mouse.
The 6 pins are +%V, Ground, X+, X-, Y+, Y-.
Grab any mouse to hack.  Look up the mouse controller chip on http://www.datasheetarchive.com/.
Desolder the IR parts from the mouse.  Take the 6 pins form the tball and solder them to the appropiate pins on the mouse chip.  Plu gin mouse :)
On the tball, the red wire should be the power.  The black wire should be ground.  For Then follow the other wires to determine axis pairs.  Then it is trial and error on which one is + and minus.  When plugged in if you move the tball up but cursor goes down the + ad - need to be swapped.
You are probably not going to find that connector.  Best get the 6 pin connector form radioshack and make your own plug.
J-Rod
  • Last login:February 10, 2008, 06:17:07 pm
  • Gaming junkie
« Reply #10 on: December 02, 2005, 04:14:40 pm »
Yeah Poonga is right, I did most of mine through trial and error, and using a multimeter to figure out what was what. + and - is just a matter of swapping. Make sure you wire up the power and ground directly to the ps2 cable, and not off points on the PCB. I tried that and kept getting +3.3, because of a resistor on the board. My .02
