Author Topic: Joysticks/buttons questions  (Read 962 times)
hnugz
  • Last login:September 14, 2013, 06:18:38 pm
    • Horrorcore Games
« on: November 15, 2005, 06:12:56 pm »
First of all, hello everyone.
I just bought my first arcade cabinet (Knights of the Round) and I am working on customizing it for Mame.  I was looking at the joysticks and buttons from happs and I can't really tell the difference between them.
First of all, the joysticks.  The way I see it, it comes down to the Super and Universal sticks.  I want to be able to switch from 8 to 4 way and these two apparently provide that capability.  It looks like you switch on the universal one just by turning the knob.  What about the super?  What/where is the actuator that you flip?  I can't tell from the picture.  Is there any other difference between the two I should be aware of?  I'm worried that I will constantly accidentally switch between 8 and 4 way with the Universal one, is this a problem?
For the buttons it looks like I can pick between Competition and Ultimate.  I can't really notice much of a difference between these.  Is there anything I should be aware of for mounting or anything?
Thanks for the help.  I will post a link soon in the new cabinet section!
"Don't play pinball if you only got one arm, cuz your score will suck."
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
Re: Joysticks/buttons questions
« Reply #1 on: November 15, 2005, 06:24:59 pm »
Welcome.
There is a search feature located along the toolbar up above. You will find 100's of posts on this topic that will answer your question on Joysticks, Joystick Review, Actuators, Button Types, etc...
I would write something up, but you'll find exactly what you're looking for using the search feature.
I had a quick look at HAPPS
http://www.happcontrols.com/joysticks/super_joy.htm
I think it is only switcheable from below.
Good Luck
« Last Edit: November 15, 2005, 09:28:15 pm by Jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
ArcadEd
  • Last login:March 04, 2012, 01:25:15 am
  • Arcade-In-A-Box , Relive Your Childhood
    • Arcade-In-A-Box
« Reply #2 on: November 16, 2005, 11:04:51 am »
Ultimarc and GroovyGameGear both have top switchable joysticks as well.  In case you wanted to go that route.
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
« Reply #3 on: November 16, 2005, 12:14:11 pm »
You might also want to buy the Saint's book; Project Arcade. That will give you some offline information.
http://forum.arcadecontrols.com/index.php/board,19.0.html
Oh, and with the Universal... you won't contsantly flip. You have to rotate the top part... you'd go from a square to a diamond shape. It doesn't arbitrarily change.
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #4 on: November 16, 2005, 04:21:31 pm »
For the buttons you don't want to use vertical microswitches. I used some of those (cause they're cheaper) but they stick. Nothing is worse than sticky buttons. ;-)
Bob
mahuti
« Reply #5 on: November 16, 2005, 05:50:24 pm »
Somewhere here on the site there is a good explanation of why vertical switches are SUPPOSED to be better, but aren't.
Just pick a button that's concave with horizontal microswitches, that's long enough to go through your panel, and has Cherry brand microswitches.
