Author Topic: I have loose balls...  (Read 1185 times)
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« on: November 07, 2005, 01:02:05 pm »
hehe...
I've seen a old thread on this but didn't find it.
I have the Ultimarc J-Stik ball top.  I have the problem of it coming loose after some game play.  What can I put on them to not come loose during normal game play but only when I need to later on?
Teamwork - A group of people running around doing what I say.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
Re: I have loose balls...
« Reply #1 on: November 07, 2005, 01:27:48 pm »
Put some silicone on the threads and then screw your ball back on. (Yes, groan)
I use the RTV black for car gaskets. It's great for keeping threaded things together, but still allowing you to disassemble later.
subcriminal
  • Last login:November 20, 2019, 12:58:00 pm
« Reply #2 on: November 07, 2005, 01:45:01 pm »
White PTFE tape that plumbers use on pipe threads also works.
MameJunkie
  • Eeeeeeeevil
« Reply #3 on: November 07, 2005, 01:56:00 pm »
I have some of them lying around.  I'll give that a try.  Thanks.
Bones
  • [Moderator]
« Reply #4 on: November 07, 2005, 03:12:08 pm »
Use Loctite 222 thread locker (222 is low strength). They will not come undone again under game conditions but can still be removed with normal tools if required.
Silhouette
  • Last login:November 28, 2021, 07:37:39 pm
  • SONIC BOOM!!!
« Reply #5 on: November 07, 2005, 04:45:45 pm »
Maybe you should wear tighter pants! *badum-tish*
Seriously though, head to your local auto parts store and pick up a $3 tube of epoxy putty (it may be labeled as 'Gas Tank Repair Putty'). It smells like burning hair, but it cures in 5 minutes, fully cures in an hour, and dries rock hard. Stick some on the threads, screw the balltop onto the shaft, and wipe off the excess putty. It'll never come off again, though, so make sure that you really want it to stay.
MameJunkie
  • Eeeeeeeevil
« Reply #6 on: November 07, 2005, 04:51:52 pm »
I want the option to remove it if I have to.
skippy
  • Last login:January 02, 2014, 05:23:26 pm
« Reply #7 on: November 07, 2005, 04:56:22 pm »
Sounds stupid, but I just used some of my kids white elmer glue.  Just a little bit kept it on and was real easy to break the bond a few months later when I built a new control panel.
I used to be cool,  then they changed what cool was
MameJunkie
  • Eeeeeeeevil
« Reply #8 on: November 07, 2005, 05:19:46 pm »
skippy
« Reply #9 on: November 07, 2005, 07:21:04 pm »
"the shaft" This thread could be in everything else real easily. All we need is a little more innuendo and start talking about somebodies mom and we are so there.
wrench
  • Last login:January 07, 2011, 05:06:14 pm
  • Another project I couldn't say no to
« Reply #10 on: November 07, 2005, 08:28:23 pm »
I'd have that looked at by a professional if I were you
LPZ
  • Last login:April 11, 2015, 01:55:21 pm
  • 2nd place is the first loser!
« Reply #11 on: November 07, 2005, 08:29:00 pm »
On the bottom of the shaft, there is a slot.
Dual 50 Caliber Continuous Fire Leon Type Machine Guns......OH YEAH!!!!!
