Main > Main Forum
What trackball is this ?
SirPoonga:
--- Quote from: RayB on October 31, 2005, 01:52:20 pm ---I have one (MC cocktail). I rebuilt the TBs. Definitely not drum.
ok, so it;s the big atari balls that use the drums.
Level42:
Thanks gusy, so is it any good ? It's fairly cheap...
RayB:
--- Quote from: Level42 on November 04, 2005, 06:01:01 pm ---Thanks gusy, so is it any good ? It's fairly cheap...
How cheap?
Do the optics work?
Are the bearings and rollers original?
A TB that age usually needs new rollers. And perhaps new bearings. If the optics don't work, you'll need new optics. And that yellow ball, how about replacing with a new white one.
Congratulations. Your cheap trackball just cost you a fortune and all you're really left with as original is the metal frame. ;D
MinerAl:
What Ray said, but there is some hope if the bearings are salvagable and the rollers aren't too badly hour-glass shaped. You can do some reviving of the bearings by soaking them in WD-40 for a good while and working any rust off of them. If the rollers aren't too bad, cleaning all the wd-40 out of the newly de-rusted beearings and lubing them really well with 3-in-1 oil (or your favorite machine lube) will take a rough spinning ball a long way toward smooth operation.
Oh, and the ball isn't yellowed, it was never cueball white. They are "cream" colored.
Take a look at the rollers, if they aren't too badly concaved then go for it.
PacManFan:
I've got one of those too.
Get yourself some hex wrenches, and take the entire thing apart, clean it out, get some silicone lubricant for the bearings, and run them with a power drill until you break out all the dirt/dust.
My 5" trackball is now the centerpiece of my CP.
-PMF
