Author Topic: quick question about comp molex  (Read 1005 times)
Abomination
  • Last login:December 07, 2023, 11:18:15 am
« on: October 23, 2005, 12:55:00 pm »
Is there any way to tell which have +5v and which are carrying +12v without using a multimeter (ie visual or what its attached to?)  Also, I have an ipaq4 and I'm using 360 opticals, I just hook up the +5v wire to the computers power supply and the ground to the common ground spot on the ipaq?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: quick question about comp molex
« Reply #1 on: October 23, 2005, 12:57:22 pm »
You might already know this but you can get your +5 right off of your IPAC4.
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #2 on: October 23, 2005, 01:22:13 pm »
The standard is RED -> 5v  YELLOW -> 12v
But I always check first, because you never REALLY know without testing.
-- Chad Tower
Abomination
« Reply #3 on: October 23, 2005, 01:47:24 pm »
Thanks, also am I correct on the optical 360's ground, connect it to my common ground wiring harness thats connected to the ground of the ipaq or do I connect it to the ground of the molex?!
markrvp
  • NFL Expert
« Reply #4 on: October 23, 2005, 02:04:48 pm »
Either ground should work, but I would (and did) connect both 5v and ground to the Ipac.
Abomination
« Reply #5 on: October 23, 2005, 02:57:30 pm »
how do I connect the 5v to the ipaq?  All I see is that header pin but no ways to connect it?
markrvp
  • NFL Expert
« Reply #6 on: October 23, 2005, 04:37:27 pm »
If you have an old CD-ROM cable that is used to connect the audio pins of the CD-ROM drive to the soundcard you can use that.  If you have an old computer case, you can cut loose one of the motherboard connectors (like Reset, Power, H.D.D., LED) and use that.
The spacing of the pins on that header is the same as the pin spacing on a Hard Drive, Motherboard pin header, etc., so any connector that will fit on those can be modified to work on the Ipac header.
If you don't have any of those available then just connect them to the PC power supply.  The red wire is 5v and the black wire closest to it is ground.
