Author Topic: slot cutter bit 3/32  (Read 1135 times)
Nataq
  • Last login:October 21, 2023, 09:09:45 am
  • Arcade of the dead... now alive!
« on: October 21, 2005, 02:42:48 pm »
This is what I need for a 3/4 t-molding bought at tmolding.com ?
http://cgi.ebay.ca/1-pc-1-4-SH-Slot-Assembly-Router-Bit-4-Cutters-Set_W0QQitemZ6007418840QQcategoryZ50386QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
specifically the 3/32 bit showing there...
wanna make sure...
whammoed
  • Last login:Yesterday at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
Re: slot cutter bit 3/32
« Reply #1 on: October 21, 2005, 03:29:20 pm »
I use 1/16 for 3/4" tmolding but 3/32 would probably work as well.  I'm sure someone else will chime in with confirmation.
Lilwolf
« Reply #2 on: October 21, 2005, 03:53:28 pm »
Is that the size that some people where having troubles keeping the tmolding to stay without gluing?
Ldsfunaz
  • Last login:March 07, 2006, 06:32:01 pm
  • "Super NinCadeO, Sega Genesis!!"
« Reply #3 on: October 21, 2005, 04:16:20 pm »
I think so, I don't see why you would need to go bigger than 1/16" because that seems to be perfect for my t-moulding.com order.
-LDS-
tray262
  • Last login:February 13, 2022, 07:07:52 pm
« Reply #4 on: October 21, 2005, 04:29:30 pm »
I would stick to the 1/16". If you are buying this because it is cheaper, I'd suggest taking a roll of doulbe sided tape (3/4" wide roll, and not the foam stuff just the thin stuff) and taping over the slot then pushing yout tee molding in, it will make a tighter fit plus it adds adhesive. just my $.02.
Good luck.
jcrouse
    • CPViewer
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #6 on: October 22, 2005, 12:09:45 am »
Stick with 1/16" slot cutter.  Why you ask?
To center the slot in the wood, make sure to flip the piece over and recut the groove.  This makes the groove perfectly centered.  Usually you are just slightly off on trying to center the cutter, so you end up with a groove slightly larger than 1/16" cutter.
