Main > Audio/Jukebox/MP3 Forum
Virtual Jukebox Version 3.0
<< < (9/9)
BobA:
I have a ripping utility that works just fine.  I don't see a need to add it to VJB.  That way you can focus develpment on VJB operational features and not get too far away from the basic program.
BobA
amsTaTic:
--- Quote from: BobA on January 22, 2003, 01:21:57 pm ---I have a ripping utility that works just fine.  I don't see a need to add it to VJB.  That way you can focus develpment on VJB operational features and not get too far away from the basic program.
BobA
Ditto  ;D
I do have one question though, concerning the new licensing. I have just begun to play around with the idea of building a jukebox for my game room. I have scrapped together some older computer equipment to get it started, but I will probably upgrade to better equipment/OS in the very near future. In fact, I just ordered some of it today. Will there be a problem when I go to re-install VJ on the new system? Or will I be able to get a new license without a hassle?
TIA
JLR2000:
I'm wondering the same thing - I have a registration code now.  I plan to build a jukebox sometime in the near future.  I'd like to get the program configured and running on one of my current PCs.  When construction is complete, I will most likely put another PC in the jukebox with my existing harddrive containing all of my music and covers.  I would reload the PC with the bare minimum Win98 load and then install VJB, pointing to all my config files/music on the music harddrive.
Will this work, or will we need to contact you in these circumstances?
VMJ Team:
The new security measures are only too prevent pirating...simply submit the new serial and I'll give you a registration code.  I'm not trying to track every time the software is installed....I'd support a copy of VJ on every computer that you own "Personally"...now if someone is requesting a new reg code every other day...there's something going on there (that's what I'm trying to prevent).
Testing update:  I'm running VJ through the works to catch as many bugs as I can so the beta version will be close to release...so far, I have only found one and fix it...search mode.  Here's how the new search mode works:  The first time you do a search, VJ needs to load all of the album and track info into a text file (this is what slowed down album loading in version 2).  Once album info is loaded into the search text...VJ will store the text until the program is shut down, or until a different music library is selected.  I've added a progress bar to the loading operation.  So far so good...still looking at a tomorrow (1/22) beta release.
JLR2000:
Thanks Cyber....that's kinda what I figured-
Looking forward to the next version......and getting my Jukebox project started some day.... ;)
Navigation
[0] Message Index
[*] Previous page
Go to full version
