Author Topic: HELLP !! how do I take out router bit  (Read 865 times)
SNAAKE
  • Trade Count: (+29)
  • Last login:January 11, 2024, 12:21:50 pm
  • my joystick is bigger than your joystick !
« on: October 07, 2005, 09:39:13 pm »
Um...soo... ???
I put this slot cutter bit like 2 years ago but I cant figure out how to take it out.I cant remember exactly how this works little help ??
Attached some pics,thanks in advance.
SNAAKE
Re: HELLP !! how do I take out router bit
« Reply #1 on: October 07, 2005, 09:40:28 pm »
last pic is the flush trim bit I am trying to put on the router.
BobA
  • What Me Worry?
« Reply #2 on: October 07, 2005, 10:07:51 pm »
EASY:
First unplug the router.
Use the lever on the side of the router to lock the spindle.  Then use the wrench that came with the router to lossen the collet or chuck that is holding the slot cutter in place.  The slot cutter shouls slide out when the collet is lossened.
BobA
SNAAKE
« Reply #3 on: October 07, 2005, 10:22:50 pm »
How does this wrench look like ? ? I gotta look for it but I dunno know what I am looking for here.
« Last Edit: October 07, 2005, 10:28:46 pm by SNAAKE »
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:August 16, 2020, 02:42:43 pm
  • I am t3h GAY!!!
« Reply #4 on: October 07, 2005, 10:40:16 pm »
It looks like any other cheap wrench that comes with a power tool. :P
Any open wrench will do though, as long as it is the right size. You just need to fit it to the hex shaped black part right there where the bit plugs into.
BobA
  • What Me Worry?
« Reply #5 on: October 08, 2005, 12:52:28 am »
Could be black or silver and made of flat metal stock.
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #6 on: October 08, 2005, 07:46:53 am »
Mine came with two wrenches. You use both at the same time (one on each of those hex thingies) and in two directions. Gives you awesome leverage to ensure a bit is in there really good or to free it.
You can use two adjustable wrenches too. You don't need the cheapie ones that came with the router.
-pmc
Captain_Dingo
  • Last login:November 28, 2018, 05:57:32 pm
« Reply #7 on: October 08, 2005, 09:26:15 pm »
That Ryobi locks the spindle with the button / lever that is on top of the motor housing.
Once it's locked, either get the wrench that came with it, or any 9/16" wrench you have laying around.  With the bit up, insert the wrench into the open window on the side of the router, put the wrench on the black hex nut just below the bit, and turn counterclockwise to loosen the chuck.  Then just pull the bit out.
