Author Topic: is the optipac needed?  (Read 1630 times)
mo1e
  • Last login:May 28, 2013, 10:07:02 am
  • Do the happy dance
« on: September 30, 2005, 06:05:30 pm »
hi all im going to purchase the ipac from ultimarc and 2 ps/2 trackballs but can these be connected to the ipac? or do i need t opurchase an optipac?
Bones
  • [Moderator]
Re: is the optipac needed?
« Reply #1 on: September 30, 2005, 06:09:08 pm »
IPAC has nothing to do with spinners or trackballs it is to detect "keystrokes" only. If you get ps2 trackballs then no, you do not need the Optipac as the trackballs will plug directly into your computer.
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #2 on: September 30, 2005, 06:11:15 pm »
Bones, I've been discussing this with Mole in the B/S/T thread. Can he plug both PS/2 connectors to his computer? That means he would need two PS/2 ports. Worst case, he could get a PS/2 to USB converter adpater. Would Windows detect both trackballs?
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
mo1e
« Reply #3 on: September 30, 2005, 06:13:45 pm »
i would also now like to add the main fact im connecting the ipac to my xbox console using the xbox adapter i need to know does the ipac have 2 ps/2 ports?
Bones
  • [Moderator]
« Reply #4 on: September 30, 2005, 06:17:15 pm »
I know when I have a USB and serial mouse plugged in at the same time they act as one. I really don't know if/how they would be individually configured in MAME.
Good question for the software geeks.
mo1e
« Reply #5 on: September 30, 2005, 06:18:31 pm »
what i want to do is be able to use one trackball for the player 1 right analogue stick on the xbox controller and the other for player 2
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #6 on: September 30, 2005, 06:37:54 pm »
What is this plugging into ? A PC ? XBox ?
Makes a pretty big difference ... as far as I know, Andy's XBox converter does the standard substitution of digital controls for analog. No option for real analog controls that I am aware of.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
mo1e
« Reply #7 on: September 30, 2005, 06:40:19 pm »
ok this is for the xbox for the left analogue stick i was going go use a happs 8 way and for the right analogu stick on the xbox controller i was going to use a rollerball as the right analogu stick is used alot for aiming in games such as first person shooters
mo1e
« Reply #8 on: September 30, 2005, 06:44:19 pm »
heres what i mean
CheffoJeffo
« Reply #9 on: September 30, 2005, 06:51:45 pm »
I didn't know that you could connect a trackball to an XBox ... you sure can't do it with the XBox adaptor that I have seen.
per Andy's notes on the subject:
Important Note: The X-Box controller contains some analog controls, and your arcade control panel has switch-type controls. This means that pressing each switch simulates the analog control being pushed hard across. Some games (flight sims for example) cannot be played with switch-type controls.
This is pretty standard for every console/arcade kit/hack I have seen.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
mo1e
« Reply #10 on: September 30, 2005, 06:56:22 pm »
ok so basically i should just get 4 8way controls instead of 2 and 2 trackballs?
CheffoJeffo
« Reply #11 on: September 30, 2005, 07:04:32 pm »
My impression (and I am out of my element here) is that Andy's XBox Adaptor is for use with a two-player panel (e.g. one stick and 8 buttons per player). You can have one player use all of those controls (the stick becomes the two analog controls, the P2 buttons become the D Pad), but can't do it for two players simultaneously.
http://www.ultimarc.com/xba.html
Maybe someone on the Consoles board has better info.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
mo1e
« Reply #12 on: September 30, 2005, 07:11:58 pm »
ok so is this correct for 2 player games like fighting i use 1 stick each then for games like halo i play one player using both analoque sticks?
CheffoJeffo
« Reply #13 on: September 30, 2005, 07:13:49 pm »
That is the way I read it.
I do not own an XBox, so you may want to pose your question in the Consoles board.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
mo1e
« Reply #14 on: September 30, 2005, 07:29:45 pm »
yep thats the way i read it to and only an ipac will be needed for this right?
Jabba
  • D-Hutt
« Reply #15 on: September 30, 2005, 07:33:09 pm »
Mole, I wish I could help but am not familiar with Console game adapters. I think you should ask the guys this questions in the Consoles forum. I though consolte game analue sticks were more like a 49 way or a 360 style joysticks. I may be wrong though...
Sheesh, you're getting the run-around, but best be sure before you lay down your hard earned money dude!
mo1e
« Reply #16 on: September 30, 2005, 07:43:56 pm »
yer but atleast scrapping the 2 trackballs will take a load off the price tag :)
but basically if my cps like this
how will i use both hands and press the buttons?
