Author Topic: Seven Button Games  (Read 3255 times)
terabit
  • Last login:June 27, 2008, 08:12:25 pm
Seven Button Games
« on: September 27, 2005, 07:11:57 pm »
What are the popular mame games that use seven buttons? Trying to figure out if it is worth the space of adding seven or six buttons on my control panel.
Later
Glenn
NoOne=NBA=
Re: Seven Button Games
« Reply #1 on: September 27, 2005, 07:27:40 pm »
The 7-button layout is used to allow both Capcom (6-button) and Neo-Geo (4-button) games to be played properly with one bank of buttons.
The Capcom games use this layout
    O  O  O
    O  O  O
X
The Neo-Geo ones use this one.
     X  X  X
    O  O  O
O
DaveMMR
    • TeeVee Games
« Reply #2 on: September 27, 2005, 08:32:09 pm »
Seven buttons also comes in handy if you're going to run a SNES emulator on your cab (assuming you have a Start button - and if you don't then that pretty much kills any chance of starting a game - and the seventh button has a unique mapping).
Flinkly
« Reply #3 on: September 27, 2005, 11:32:28 pm »
not to confuse the noob, but i prefer the 4 buttons to be accross the top, but everyone else is right that it's not so much seven button games, but the comfort and convenience of having the appropriate buttons in the appropriate spot.
NoOne=NBA=
« Reply #4 on: September 27, 2005, 11:38:06 pm »
I don't like having to reach over buttons to use other buttons.
It just feels funny to me.
I tend to rest my hands on the machine heavily when playing (to the point of actually leaning on the machine), so I like to have a solid surface there.
Flinkly
« Reply #5 on: September 27, 2005, 11:40:54 pm »
so what games do you have to remap to make that work well?  all games that require less than 4 buttons would start on the bottom row, and then games that used 6 would start on the top?
AtomSmasher
    • Atomic-Train
« Reply #6 on: September 28, 2005, 01:51:19 am »
Heh, I had no idea why 7 buttons were used, but I saw the majority of CPs had 7 so I put 7 on mine.  I always figured it was because there were 7 button games, but it makes sense that the bottom row is for neo geo games.
« Reply #7 on: September 28, 2005, 06:57:06 am »
There are pro's & con's to having 7 buttons.  Personally I was using a 7-button test panel for a long time but for my final version decided to go with 6.  Part of the reason was that I found when using the P2 stick in my right hand (for double-joy games like Robotron) the 7th button would kindof irritate me (always being underneath my hand).  I also found it probably easier to use the 6 button setup for NeoGeo games, rather than the more authentic method with the 7 button layout.
terabit
« Reply #8 on: September 28, 2005, 10:23:46 am »
Minwah, thanks for the advice. My cab is mainly for Robotron, so I think I will use the six button setup. Check out my control panel and let me know what you think.
http://forum.arcadecontrols.com/index.php?topic=43667.0
Glenn
« Reply #9 on: September 28, 2005, 10:34:15 am »
I like your design :)
As long as you are not a real NeoGeo fanatic/purist I would definately leave the 7th button off.
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
« Reply #10 on: September 28, 2005, 12:30:06 pm »
Minwah, that is a design issue then, you can still have 7 buttons :)
I have the 6 button layout to.  I don't play enough 4 button neogeo games.  I mostly play the non-fighter neogeo games.  The few that need a 4th button then isn't a big problem.  my neogeo layout is like
XX4
123
My regular layout is
456
123
For fighters I do remap to
123
456
Flinkly
« Reply #11 on: September 28, 2005, 01:43:29 pm »
call me crazy, but i've always planned to make mine
1234
456
besides the "it stinks to reach over the lower row of buttons", doesn't it look like it works well?
i've tried it out before and never felt a problem, but i guess i'm just used to it.  also, i don't have to reconfigure anything.
« Reply #12 on: September 28, 2005, 02:18:47 pm »
Yes, but I used the 'standard' layout, which 90% of people use...so they'd probably find the same thing.
In any case as I said I just decided I didn't want the 7th button.
SirPoonga
  • Puck'em Up
« Reply #13 on: September 28, 2005, 02:31:52 pm »
Minwah, standard meaning they put the buttons as close to the joystick as possible?  Otherwise wouldn't all oyu have to do is move the b utton over a bit?
Fuzzguitar
  • Last login:November 26, 2012, 12:15:34 am
« Reply #14 on: September 29, 2005, 12:41:01 am »
Forgive me if I'm wrong as I've been out of the scene a while but didn't one of the Mortal Kombat games use 7 buttons?
For some reason I thought I recalled reading that.
"My cab is nearly finished, no really I swear!"
« Reply #15 on: September 29, 2005, 05:47:55 am »
Well yes I could have moved all the buttons over...but I didn't really want to, it would look odd IMO.  Plus it would force the 2 player's controls closer to each other, which is an issue for me as my CP is only 60cm wide.
Granted this is pretty trivial anyway.  The main reason I changed is probably because I realised I don't actually *like* the NeoGeo button layout!
Fuzz: I *think* the most buttons any MK game uses is 6, but some people like to use 2 of the buttons for the same thing, so they use 7 in total.  I could be wrong on that tho...
Fuzzguitar
« Reply #16 on: September 29, 2005, 08:04:43 am »
Minwah, I'll forgive you if you're wrong, after all you've never charged me for using Mamewah - the greatest FE around!
I also have a 60cm CP on my cab so I know what you mean in regards to space.
I'm just ordering parts for my second cab now and I'll be sticking with the capcom 6 button layout. I don't like the idea of having to explain to all my guests that neo-geo games use the lower row of buttons...they don't need to be confused by things like that.
« Reply #17 on: September 29, 2005, 11:44:08 am »
That's another good point.  As I say I think only NeoGeo purists need the 7 button style.
BTW is that Belle & Sebastian in your avatar?  I remember that...
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #18 on: September 29, 2005, 04:03:44 pm »
The only MK games using 7 buttons aren't supported by MAME.......and I'm not sure they even had arcade versions.
There are a couple of 7 button games that are, but I can't recall which ones at the moment. The number is very low though.
Fuzzguitar
« Reply #19 on: September 30, 2005, 06:03:57 am »
Yup, it's Belle & Sebastian, waiting patiently for someone to release it on dvd....
yugffuts
  • Last login:August 19, 2011, 01:22:57 pm
« Reply #20 on: September 30, 2005, 08:20:19 pm »
You were close on the MK comment.
