Main > Main Forum
The best motherboard for a cab?
Pages: << < (3/3)
spystyle:
I will have to do some comparitive tests when time allows using freeDOS and Windows 95, 98, 2K, and XP.
Maybe I'll test Linux too, there must be documentation to get that running...
I guess the proper way to compare is to pick a particular game and check the FPS?
Craig
subcriminal:
PC chips K7 mobo!
jhanson:
--- Quote from: spystyle on September 27, 2005, 08:40:05 am ---As for the common onboard sound, AC97. I bet someone has written a DOS driver for that...
If you want DOS drivers for AC97, you can get them by clicking here.  You want the viaaudio.com file out of that archive.  Works flawlessly on all of my AC97-based DOS systems.
wpcmame:
--- Quote from: arcadecollecting on September 27, 2005, 02:12:57 am --->DOS MAME so you don't have to wait for Windows to load.
When using hibernate the time to startup windows with frontend is about as fast as DOS. The frontend doesn't need to parse roms, load images etc which compensates for the few seconds it takes to load the hibernation file.
Another benefit is that you can hibernate in the middle of a game and then return to the same position later.
Havok:
Go with XP and strip it down. Boots fast, and you get USB support and works with virtually every piece of hardware known to man. Do it right, and it boots almost as fast as DOS - and you will get better drivers, which gives better performance.
Linux is also an excellent choice. Some of the distros boot even faster than my stripped down XP image. However, since I have been a M$ whore since '87, I use what I know best...
Pages: << < (3/3)
Go to full version
