Author Topic: Do we have the dimensions for Robotron or similar Williams cab?  (Read 960 times)
spystyle
« on: September 26, 2005, 07:18:04 pm »
Hello from Maine
I am looking for dimension to Williams 1982 style cab, like Robotron, Joust, or Bubbles.
A pic of the front and side "straight on" could work as I could add 1" squares to it in PaintShop and call it a quick plan.
Thank you,
Craig
« Last Edit: September 27, 2005, 04:18:14 pm by spystyle »
CIA_Guy
  • Last login:June 20, 2011, 08:30:50 pm
  • You mean there are games other than Defender?
Re: Do we have the dimensions for Robotron or similar dated Williams cab?
« Reply #1 on: September 26, 2005, 08:02:34 pm »
Did you try looking at the links under "Cabinets" on this board? ::)
Try Jacobud's site:  http://www.jakobud.com/
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #2 on: September 26, 2005, 10:03:45 pm »
I just took a look and only saw a Robotron cocktail on there.
One thing with the Robotron is that rounded front is wood. Looks like it'd much trickier to recreate than a Defender or other "normal" cab.
CIA_Guy
« Reply #3 on: September 26, 2005, 10:50:03 pm »
There are two Williams cabs there -- Stargate and Defender.
spystyle
« Reply #4 on: September 27, 2005, 05:42:06 am »
I think Stargate has roughly the same dimensions in the middle, but I'll need the dimensions for the side panels.
Thanks,
Craig
spystyle
« Reply #5 on: September 27, 2005, 06:39:01 am »
Well it isn't beautiful but should be functional. I found a pic of the side of a Joust and put a 1" grid over it based on the dimensions from the flyer (28.5" deep by 70" tall)
That combined with the inner dimensions from the Stargate plan should  make a nice Joust, Robotron, Bubbles style cab.
Dig it?
Craig
KenToad
  • Last login:May 05, 2024, 08:22:38 am
  • Flap Flap Flap
« Reply #6 on: September 27, 2005, 02:57:46 pm »
Here's the pic I used for my cab.  It looks slightly taller than your pic.  Or am I dreaming? ???
Cheers,
KenToad
spystyle
« Reply #7 on: September 27, 2005, 04:16:50 pm »
Yes, it's taller.
In my pic the plan keeps on going as indicated by the red squares.
70 inches tall, 70 squares.
I figured it didn't matter too much that the bottom of the pic was missing.
Craig
