Main > Software Forum
Johnny 5 beta 2.0 released!
Tiger-Heli:
AllisterFiend - Great find - I updated http://www.mameworld.net/tigerheli/johnny/ahk_th.htm to reflect your method.
diabolic:
--- Quote from: Tiger-Heli on October 22, 2005, 07:42:19 am ---AllisterFiend - Great find - I updated http://www.mameworld.net/tigerheli/johnny/ahk_th.htm to reflect your method.
Tiger-Heli:
--- Quote from: diabolic on October 22, 2005, 12:59:12 pm ---I had to add a } to the script for method 5 to work for me.
Is it wrong on my page?
Where did you add it?
diabolic:
--- Quote from: Tiger-Heli on October 22, 2005, 01:03:50 pm ---Is it wrong on my page?
Actually I added { and }.
Howard_Casto:
Just to go over the ahk limitations discussion.....
It is indeed a 98 problem. 9X handles low level input differently than a NT based environment does. The reason notepad and more "windowsey" apps aren't affected is because they only use high level input scanning and don't hook the keyboard buffer. Basically anything running direct input in exclusive mode, allegro's input system or anything similar isn't going to work. (Read 99% of all emulators.) Apps coded in visual studio languages (like notepad and many of the apps that come with windows) will. Daphne probably has about a 50/50 shot in 98 as sdl seems to be less picky. Some of the console emulators support sdl input plugins so that might be a solution for them. Otherwise, you are sol.
You'll notice that j5 detects the inputs in 98 as well. That's because I used vb6 to code it and I don't use any fancy hooking methods.
Navigation
[0] Message Index
[*] Previous page
Go to full version
