Main > Main Forum
Get Your Butts Over to the BYOAC People Finder and Register!!!
finsailor:
Wow, I never noticed that. I would have needed that a couple of years ago when I started to build my cab, which by the way is still not finished.
I just added me to this list, but why cannot you just use the byoac member db for this???
missioncontrol:
did you not see my last post???
it's broken you cannot add yourself to it :(
if you get through your emails will bounce back
there is a replacement in the works....
the byoac db is only partial alot of people do not put their location in their profile.....
mccoy178:
Well, I guess it would be nice if Sir Woogie would make an appearance and clarify the issue as I feel this is a very useful tool. :police:
Kremmit:
Don't waste your time with the current PeopleFinder. It's dead, dead, dead.
If you want one that works, message the powers that be.
Goz:
An integrated solution powered by the info in the boards DB is the best solution to this. I was working on creating a new one, but have run out of time and without access to the profile info have no way to automagically populate it.
The Mods are best suited for creating or implementing an integrated solution.
