Author Topic: Curious resolution question  (Read 697 times)
IG-88
  • Last login:May 09, 2023, 08:29:46 am
« on: September 18, 2005, 10:07:33 am »
I'm not sure quite how too explain this and it's probably too vague a question but I am wondering why my 64mb ATI all-in-wonder 7500 vid card produces a much more realistic/authentic looking arcade like picture than any other card I've tried? On a PC monitor it just looks fantastic, whereas my 128 mb XGI Volari V3 card (or any other I've tried) displays a more blocky, sharper image. Which is OK,
-HarumaN
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Curious resolution question
« Reply #1 on: September 18, 2005, 12:52:25 pm »
Those are scanline effects done (partially) via DirectX, and not all cards have the features required for them.
NO MORE!!
IG-88
« Reply #2 on: September 18, 2005, 01:25:49 pm »
Would you happen to know of any other cards besides the all-in-wonder that can do that?
-HarumaN
RayB
  • There's my post
    • RayB.com
« Reply #3 on: September 18, 2005, 05:34:53 pm »
I have no idea. There are other factors as well that could affect the display. For example, are you using 100% the exact same configuration for both cards you tested? If you used MAME32 on one and then a different MAME (DOS or Windows command line MAME) for the other, that would also affect the display output.
NO MORE!!
« Reply #4 on: September 19, 2005, 06:25:11 am »
The images with the ATI are smoother, (blurred??) more arcade like, and if you set 2 monitors up side by side with one running the ATI and one running any of my other cards, there is a definite difference.
Sounds like the filtering which occurs with many (most?) video cards, when using hwstretch.  Maybe your other card can stretch without the filtering.
IG-88
« Reply #5 on: September 19, 2005, 04:10:32 pm »
-HarumaN
JB
  • Last login:October 21, 2005, 10:56:01 pm
« Reply #6 on: September 19, 2005, 04:57:55 pm »
Lets see if I understand you correctly. The filtering that occurs with my other cards using hwstretch is what makes the images display with a more "blocky/sharper image" and my ATI card is (possibly) stretching without using filtering? Correct? So... how do I get my other cards to stretch without filtering? Or is that even possible? Is there a setting in Mame that can do this?
Other way around. The cards that stretch WITH filtering makes the display look blurry.
Which is a good thing when dealing with software that expects a blurry display.
It's possible to force cards that normally stretch with a filter to stretch without one, but I don't think the opposite is true.
Silver
  • Last login:February 17, 2024, 10:29:00 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #7 on: September 19, 2005, 05:33:55 pm »
How much of a difference are you talking? Could you post a couple of comparison pics?
IG-88
« Reply #8 on: September 20, 2005, 02:07:23 pm »
I'll try and post some pics, tho my camera sucks.
-HarumaN
