Author Topic: Adding a volume control?  (Read 1173 times)
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
« on: September 16, 2005, 01:15:51 am »
To a standard Midway mono speaker (Pac cab.)  What's the best way to do it?  Be nice if there was a pre-existing black knobby thing I could just wire up and put in the top of the cab by the speaker that was designed for this purpose.  Stranger things have happened...
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
Re: Adding a volume control?
« Reply #1 on: September 16, 2005, 02:15:34 am »
-- Chad Tower
tivogre
  • Last login:July 18, 2013, 09:13:34 pm
    • ogredog.com
« Reply #2 on: September 16, 2005, 07:02:15 pm »
Check this out:
http://www.oscarcontrols.com/volume/index.shtml
This is almost EXACTLY what I did.  I even used the same Radio Shack POT!
Here's mine in the center of my admin panel:
It works FANTASTICALLY!  Also, no mods required to the speakers / amp.
You will (probably) need a 1/4" shaft extender.  I had a hard time finding one of these.
I ordered mine from here:
http://www.oselectronics.com/ose_p100.htm
I used the shaft coupler (SC120) and cut a length of 1/4" aluminum rod to get the exact projection through th panel I needed.
Good luck!
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: September 16, 2005, 07:14:36 pm »
I don't know if this needs mentioning or not, but keep in mind that the pot will only REDUCE volume. If you want some sort of INCREASE in volume, you need an amplifier.
NO MORE!!
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« Reply #4 on: September 17, 2005, 11:41:49 am »
premade volume control perfect for mame cabs:
http://www.3tronics.com/VC01A_Info.htm
tivogre
    • ogredog.com
« Reply #5 on: September 17, 2005, 11:49:27 am »
Yes, but...
     1.  It's Out Of Stock
     2.  It's $36 + shipping?!?
We're talking about less than $10 in parts for the build your own version.
spystyle
« Reply #6 on: September 22, 2005, 06:40:38 pm »
« Last Edit: December 09, 2006, 10:06:22 am by spystyle »
