Author Topic: 3 way switch use on i-pac  (Read 2000 times)
astrothug
  • Last login:June 25, 2017, 05:50:19 pm
  • I have built and ready to build again
    • davids mame
« on: September 15, 2005, 10:32:58 pm »
i have this switch on my GP Rider motor cycle it looks like a 3 way switch so you can adjust throutle of brake its also used in for left and right, can i use this switch in mame and my i-pac thanks heres a pic
jedi27
  • Last login:June 11, 2007, 11:07:28 am
  • Models make people feel good about themselves.....
Re: 3 way switch use on i-pac
« Reply #1 on: September 15, 2005, 10:42:11 pm »
Looks like a potentionometer == pot to me...  it's a variable resister - not a switch at all.
Perhaps I'm looking at the wrong item in the photo???
astrothug
    • davids mame
« Reply #2 on: September 15, 2005, 10:46:27 pm »
no i think your right its thw round thing with 3 wires coming of it...
I m thinking I cant hook this up to my i-pac ? but could be wrong.. thanks
jedi27
« Reply #3 on: September 15, 2005, 10:48:33 pm »
no problem - look around these examples for people hacking analog type controls - such as steering wheels - you may be able to do something with the control after all.
astrothug
    • davids mame
« Reply #4 on: September 15, 2005, 11:01:24 pm »
will an opti-pac work ?  I have left and right,  throtle and brake that I would be wirring to this, i cant use the ipac couse it only open or closed switch as with this I would be needing some thing that could do degrees of left or right or lets say half throtle..
jedi27
« Reply #5 on: September 16, 2005, 12:04:34 am »
I guess an optipac could work - I've only wired miine for a trackball, but from what I recall there are indeed 4 available axis (2 "mice").  It's not the cheapest solution, but I'm happy with how mine works.
Have you considered hacking a mouse or two?  Just a thought...   Also keep in mind that the opti pac (from what I understand) relies on an optical sensor output - what you have are just variable resistors.  If this is truly the case then no, they wouldn't work without some modifications...
astrothug
    • davids mame
« Reply #6 on: September 16, 2005, 12:22:27 am »
i think i got it its callec a-pac
http://www.ultimarc.com/a-pac.html
this might be the ticket
jedi27
« Reply #7 on: September 16, 2005, 12:30:03 am »
rock and roll - didn't know about that one!!!
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #8 on: September 16, 2005, 12:46:20 am »
Right, an Opti-Pac doesn't do analog controls (potentiometers).  You'll need that A-Pac or a different encoder that supports analog.
I want my own arcade controls!
astrothug
    • davids mame
« Reply #9 on: September 16, 2005, 12:51:02 am »
thats the thing there not to many encoders that support anolog, I have spent most of the night looking...lol.. and the A-pac is out of stock, Just emailed them to find out when they will be expecting more.
if anyone knows of encoders Im looking for please post the links, thanks
Bones
  • [Moderator]
« Reply #10 on: September 16, 2005, 02:24:15 am »
The most obvious solution that comes to my mind is to hack it via the joystick port but you will probably have to change over the pots to make this work.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #11 on: September 16, 2005, 03:14:51 am »
