Author Topic: REALLY thin solering pen ??  (Read 1339 times)
SNAAKE
  • Trade Count: (+29)
  • Last login:January 11, 2024, 12:21:50 pm
  • my joystick is bigger than your joystick !
« on: September 13, 2005, 02:19:14 pm »
Anybody know where I can get one...order online maybe ?? I seen this guy modding ps2 at this local VG place and he uses this really thin iron..its like a pen and I need one just like that.
I asked him where I can get one but since the guy is such a cake hole he said "I dont know" >:(
Thanks in advance !
Effayy
  • Last login:August 18, 2006, 02:09:07 pm
  • Slowest....Cab Builder.... EVER.
Re: REALLY thin solering pen ??
« Reply #1 on: September 13, 2005, 02:46:06 pm »
I saw one at Canadian Tire a few weeks ago.
« Last Edit: September 13, 2005, 02:48:05 pm by Effayy »
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #2 on: September 13, 2005, 03:00:15 pm »
The tip seems to be very thick ...
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #3 on: September 13, 2005, 03:43:09 pm »
I bought an SMD soldering set with a 12V soldering iron. This is especially for soldering these surface mounted chips. I used it on my PS2 (and some SMD projects) and it worked like a charm. Was really cheap too (6 euro) I ordered it from a dutch shop, but it shouldn't be hard to find something similar in the US. Wouldn't radio shack sell something like this?
« Last Edit: September 13, 2005, 04:12:34 pm by patrickl »
SoundDoc
  • Last login:January 18, 2012, 07:24:30 pm
  • I'm a Enigma!
    • DaCab!! (a work in progress)
« Reply #4 on: September 13, 2005, 03:48:38 pm »
I wouldn't even attempt to use one of those for anything more than tinning small wire.
Its a resistance based soldering tool, and from what I hear, your lucky you get 2 or 3 soldering "sessions" about 20 secs a piece on a set of batteries.
Plus, I wouldn't take it anywhere near a circuit board, or IC, or even a led for that matter. If you were to touch two pins of a IC with it, there flows the current, right throught the IC, more likely to smoke it than solder to it.
The one workstation I have that I prefer for most all small soldering is a weller temperature controlled 50W station. (EC 1002 I think). You can find them relatively cheap online, arround $100.00 and you can get quite a few small tips for them. The one I use for smt work is .015" at the tip, and about 1" long.
If your looking at modding ps2's or any other device that requires soldering to individal pins on a smt chip (ps2's especially where you may have 4 or 5 pins in a row that require wires) you need the finest tip you can find, and good temperature control (a illuminated magnifier doesn't hurt either)...
Hope this helps!
SoundDoc
DaCab, a work in progress searching for a better name.....
http://Http://DaCab.DatPlace.com
webgeek
  • Last login:August 08, 2006, 07:05:10 pm
« Reply #5 on: September 13, 2005, 03:50:10 pm »
I'm with SoundDoc, a good soldering station will serve you well for years to come. I use a Weller with interchangable tips as well.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #6 on: September 13, 2005, 04:40:07 pm »
SoundDoc are you responding to Effay or Patrick?
NO MORE!!
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:August 16, 2020, 02:42:43 pm
  • I am t3h GAY!!!
« Reply #7 on: September 13, 2005, 06:37:00 pm »
He was responding to Effay.
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #8 on: September 13, 2005, 07:46:10 pm »
ANTEX are supposed to be pretty good.
« Last Edit: September 13, 2005, 07:47:50 pm by spiffyshoes »
MaximRecoil
« Reply #9 on: September 13, 2005, 10:02:10 pm »
« Last Edit: September 13, 2005, 10:16:04 pm by maxim_recoil »
JB
  • Last login:October 21, 2005, 10:56:01 pm
« Reply #10 on: September 13, 2005, 10:16:18 pm »
I saw one at Canadian Tire a few weeks ago.  It was an "As Seen on TV" item... Let me drudge up the details and get back to you in this thread...
EDIT:  Here it is!  I want one of these myself....
[Cold-Heat Soldering Pen]
- FA
Problem is the ColdHeat arcs electricity to heat the solder.
Essentially a static discharge into any pin you're soldering on.
Makes it all but useless for electrical components.
SNAAKE
« Reply #11 on: September 14, 2005, 01:40:40 pm »
Bump,thanks everyone.
Any others ??
As for that cold heat,I hear too many neg stuff about it it wont work for ps2 modding.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #12 on: September 14, 2005, 01:54:22 pm »
What difference are you looking for? I'd say both the Antex and mine would work fine. Those fine tips work great for PS/2 modding (did so myself)
