Main > Main Forum
I've Started - but...
Pages: << < (5/5)
DaveMMR:
--- Quote from: Cyclops on September 18, 2005, 10:33:23 am ---Well I stuffed up...er..did a bit more on my cab over the weekend...not much.
I have decided to finish this one off, but not do a marquee or light or sliding door.  Just going to get the box done, paint it, setup the buttons etc....and play.  If I haven't stopped playing it after two weeks, I am going to go and get some more wood and start again.  This time, hopefully, with a bit more planning and patience.
At least it is standing! hehe....bit wobbly side to side though.
Dude, your cab looks a hundred times better than mine right now.  Perhaps there's something I'm not seeing?   I actually have to take a few of the pieces I installed out and refit them since I noticed the measurements are off.  But, whatever, it's easier to fix problems than to scrap the entire thing and start again.
By the way, slight wobble is normal until it's weighed down (the monitor).  Just make sure it's squared off and correct it if it's not.  Also make sure you're checking the cab's intergrity on a flat surface (made that mistake myself).  Finally, make sure the bottom is flat - sanding down whatever's causing serious wobble.
Do what you want, but I say finish what you started with it.  You have no discernable major defects.
missioncontrol:
your project is looking good.....
don't sweet the minor things chances are nobody else will notice the small inperfections that you the creator will.....
Pages: << < (5/5)
Go to full version
