Main > Main Forum
Pachinko Marbles instead of Tokens?
Pik4chu:
--- Quote from: versapak on September 12, 2005, 08:10:19 pm ---
--- Quote from: Pik4chu on September 12, 2005, 05:30:37 pm ---when you are about to lose your last life push the button for another ball to drop, so you get the credit before its time to continue :P
Sure, if you wanna go ahead and be all observant like. :P
or just let your little kid play with it, plenty of credits :P
PetitMorte:
ThinkGeek sells Marble Roller Coaster construction kits. get more kits, stick em together, make giant marble rollercoasters.
ErikRuud:
I still have my BanDai SpaceWarp that I got in the 80's.
Sometime around 1972, I had a set that was sort of an ancester of the current MarbleRun sets. It consisted of pieces that were molded from translucent plastic. The colors were blue, yellow, green, and red. It had cubes with 9o degre elbow in them. Some flatter square connecting pieces, and ramps. I cannot remember who made it, or what it was called.
ErikRuud:
I just found a vide of the Marble Roller Coastser.
http://www.zippyvideos.com/42094702945595/marble_run/
The shots are very tight, but you can see that is the same set.
Pik4chu:
--- Quote from: ErikRuud on September 13, 2005, 03:38:24 pm ---I still have my BanDai SpaceWarp that I got in the 80's.
