Author Topic: Help installing Sanwa Joystick  (Read 4167 times)
jshum9999
  • Last login:September 20, 2007, 11:46:17 pm
« on: September 07, 2005, 02:28:17 am »
Hello,
I have an astro city control panel, and I just bought a sanwa joystick with the metal mounting plate.
However, the mounting plate and the area that I should mount the joystick under my control panel do not line up.
Does anyone know what i'm doing wrong?
Here are some pictures to help explain.
The first picture is where I'm mounting the joystick.
The second is a picture with the sanwa mounting plate.
The third picture is of the mounting plate, where i'm mounting it, and my previous joystick.
Re: Help installing Sanwa Joystick
« Reply #1 on: September 07, 2005, 06:00:35 am »
So the original sticks are held in with just 2 bolts?
Looks like you may need to make a new mounting plate, or could you use the plate from the old sticks?
jshum9999
« Reply #2 on: September 07, 2005, 06:11:26 am »
i thought of that, but the old mounting plates don't work on the sanwa sticks
« Reply #3 on: September 07, 2005, 11:09:50 am »
In that case I would make a new mounting plate, using the centre holes of the new plate for a guide.  You could also use the old plate as a template for where to put the mounting holes.
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« Reply #4 on: September 07, 2005, 11:41:08 am »
have a look at www.himuragames.com i get all my sanwa stuff from Rod he's a really nice guy he might be able to help you out??
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
« Reply #5 on: September 07, 2005, 11:57:30 am »
The Astro panel has the built in mount. Sanwa's are held in with just the two screws/bolts
