Author Topic: Wiring a coin mech to a computer PSU  (Read 2793 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: September 05, 2005, 08:48:44 am »
i've got a sentinel coin mech - 12v. Would it be possible to power this from a computer psu? how would you ensure you get 12v?
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
Re: Wiring a coin mech to a computer PSU
« Reply #1 on: September 05, 2005, 09:01:03 am »
The yellow wire on a PC PSU is +12V. I'm not sure if you need to know more than that... someone here will be able to tell you.
-pmc
eggedd2k
« Reply #2 on: September 05, 2005, 09:46:42 am »
how do you physically wire it to the 12v on the computer's PSU? do you have to take the case off the PSU to do this?
agfisher
  • Last login:February 02, 2009, 03:13:16 pm
« Reply #3 on: September 05, 2005, 09:53:08 am »
You should be ablr to just tap off of the Yellow (+12v) and the Black (Ground) from the Hard Drive power connectors.
Adam
Boston, MA
eggedd2k
« Reply #4 on: September 05, 2005, 10:26:12 am »
thanks. seems easy enough. what's the best way of attaching the wires?
Franco
« Reply #5 on: September 05, 2005, 10:42:13 am »
You could use some insulated disconeects like these that i used:-
Also, this site has some info on wiring the sentinal mech, including dip switch settings.
http://homepage.ntlworld.com/chris.nightingale1/arcades/cbmain.htm
pmc
    • website
« Reply #6 on: September 05, 2005, 10:59:23 am »
I used a molex hard drive cable. Plug into the PSU harness and then cut the connector off the other end. Extend the yellow and the black wire next to it (pin 1 and 2) to your destination and hook up with quick-disconnects as mentioned. Tape off, remove, or cap wires 3 and 4.
-pmc
agfisher
« Reply #7 on: September 06, 2005, 09:04:15 am »
-pmc
I do something like this but I cut all four wires and extend then to a wiring bus. Then, if i need  +12, +5 or Ground in the future, I just tap off of the bus. You can then use the quick disconnects between the bus and your application.
Adam
Boston, MA
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #8 on: September 06, 2005, 02:48:43 pm »
**WARNING**
Use a multimeter first to determine which wire is 12v. Not all manufacturers use the same color codes. Most do, but there ARE some that reverse it. Though I suppose it won't hurt anything if you accidentally apply 5v instead of 12....
NO MORE!!
Stingray
« Reply #9 on: September 06, 2005, 03:23:02 pm »
I'm not sure it's a really spectacular idea for you to be poking around inside an arcade machine. If you see something that looks like a suction cup, don't touch.
-S
tivogre
  • Last login:July 18, 2013, 09:13:34 pm
    • ogredog.com
« Reply #10 on: September 07, 2005, 01:15:17 am »
I made a cable to tap off of a hard drive power plug.
I started with a HD power splitter cable.  One branch, I removed the molex plug and soldered on a length of wire to the 12v and GND wires.
To the other end of the extension wire, I soldered 6 pairs of 12v / GND wires with QD terminals:
